Technical Need lug nut help
Discussion in 'The Hokey Ass Message Board' started by belair, Mar 10, 2018.
  1. belair
    belair
    I need this kind of lug nut, but with a 1/2 longer shank. Must have the rounded shoulder.
    Napa couldn't find them, so here I am, looking for help. Thanks.
  2. 29moonshine
    29moonshine
  3. jimmy six
    jimmy six
    go to the Gorilla Lugs site. I have that style on my 56 with AR wheels and they have different depths on the shank that goes into the wheel and the angle seating on the rim. After you find the # you want the google it for the best pricing...Worked for me...
    belair likes this.
  4. 49ratfink
    49ratfink
    I had good luck finding correct lug nuts at Jegs
    sidevalve8ba and belair like this.
  5. I like jegs, but summit has a great search and drill down function on their web site.
  6. mad mikey
    mad mikey
    Summit, and their is a guy on ebay called the lugnutking. He also has many different lug nuts and styles to choose from, and good prices. Speedway also has lug nuts.
    belair likes this.
  7. Bert Kollar
    Bert Kollar
    EZAccessory seems to have every one ever made
  8. TA DAD
    TA DAD
    from NC
    Does it take a washer ? If so it is known as a ET style conical lug.
  9. gdaddy
    gdaddy
    from nw fl.
    maybe ford ranger with mag wheels , I think they had a longer body to them .
  10. zzford
    zzford
    Ain't nothing like the flavor of smoked lugnuts on a cold winter's day.
  11. wojojo
    wojojo
    "Lugnuts roasting by an open fire"
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    What kind of wheels are you trying to put on? I bought these from the lugnut king. For a set of American TTO’s. They have a tapered seat but need the extra length for thread engagement because of the thickness of the wheels past the taper.[​IMG][​IMG]
    mad mikey likes this.
  13. mad mikey
    mad mikey
    Like I posted , check The Lugnutking. You should find what you need. Or contact him.:)
    blowby and Moriarity like this.
  14. If you're calling the part that goes through the wheel, onto the stud, the "shank", I'm not sure why you need that extra length, unless maybe your studs are too short. All the grip, clamp and holding power is only in that 60° taper. You don't ever want the shank at the base of the taper to bottom out. I hope I'm not muddying the waters with off the point info, but based on the photo, I don't see the problem. (?)
  15. blowby
    blowby
    from Nicasio Ca
    I like the Lugnutking too, met them at swap meets, but, I've never seen a tapered seat with a shank any longer than those pictured above.
  16. southcross2631
    southcross2631
    The lugnutking found me some left hand thread lug nuts for my Pontiac rear in my old Falcon for some aluminum wheels. Good price and fast shipper.
  17. belair
    belair
    Americans wheels.
    These are like the ones I have, need a 1/2 longer shank. Had to use a wheel spacer and want more thread engagement.
    Moriarity likes this.
  18. belair
    belair
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    You may end up installing longer studs. I am not sure this style lugnut comes any longer. Good luck
    mad mikey and Johnny Gee like this.
  20. belair
    belair
    No washer.
  21. blowby
    blowby
    from Nicasio Ca
  22. Okay.... now it makes sense. You might not be able to find any lug nuts with a longer shank because they're probably only made for a certain wheel thickness without spacers. Making some especially long/deep for spacer set ups may be too limited a market so they aren't available, I'm thinking. Longer studs may be your only recourse.
    mad mikey and belair like this.
