Technical Need manual transmission safety switch ideas
Discussion in 'The Hokey Ass Message Board' started by txcr13, May 17, 2018.
  1. txcr13
    txcr13
    I have done some searches, but really haven't found a lot of specific information on installing a neutral safety switch for a MANUAL transmissions. Lots of info on automatics, but that doesn't help much.
    The car is a 1946 Studebaker, Muncie four speed, with clutch and brake pedals that go through the toe board. The clutch is hydraulic. Would like to hear from any of you who have hooked up a neutral safety switch of some sort for manual transmissions. Details about where you got the part(s) and any other tips would be much appreciated.
    Thanks in advance.
  2. studebakerjoe
    studebakerjoe
    Not exactly a neutral safety switch but with a hydraulic clutch how about wiring in a hydraulic brake light switch into the ignition so the starting circuit is broken unless clutch is pushed in.
  3. coilover
    coilover
    from Texas
    I've only seen a safety switch on the clutch of a manual trans. I've had several Ford Rangers with 5spds that the clutch has to be against the floor for them to start. You might look at a wiring schematic for say a 98 Ranger to see how one is wired.
    Austin kays, zzford and tb33anda3rd like this.
  4. ^^^^ This. All the new car cars with manual trans use a switch on the clutch pedal....
    ottoman likes this.
  5. redo32
    redo32
    At first I thought, Why? I guess new cars have features we get used to. Besides the clutch, new cars with autos you have to have your foot on the brake, that would be easy to wire in the brake light circuit. Or you could put it on the emergency brake. I just realized my John Deere has a neutral switch on the stick trans, but is probably internal. If you have a Hurst shifter you would almost have to put a switch on each lever.
  6. squirrel
    A mechanical brake light switch for an old Chevy (like a 50s truck) might work on the clutch pedal, too. Those had the pedal through the floor, and the switch mounted on the bottom of the angled toe board.
    (I guess this stuff is useful in case "new" drivers have to drive the thing. Old guys, it's pretty natural to remember to push the clutch or put it in neutral before starting)
  7. mkubacak
    mkubacak
    This^^^^^
    I don't see the need.
  8. New Guys crack me up! I think seat belt Buzzers are necessary also,,, NOT!
    The Wizzard
  9. southcross2631
    southcross2631
    The clutch switch is used by the factory . Easy enough to rig up with a switch . A neutral safety switch would require some engineering by you. Some sort of centering switch on your shifter wired through your ign switch.
  10. Ned Ludd
    Ned Ludd
    I've had occasion to use the starter while the car was in gear. I once had to move my BMW 2002 a matter of six blocks or so after having lost the clutch. Jerky start in first gear until the engine started, then a deft clutchless snick into second, then a matter of making sure I didn't need to stop anywhere until I got to where I was going.
  11. F-ONE
    F-ONE
    from Alabama
    Without engineering something exotic that's over engineered, I think you need a single switch.
    The only place I see a single switch working is on the transmission case activated by one of the shift levers. The shifter just has too much play in neutral....."multipositional".....
    One of the shift-levers is in a pretty much fixed position in neutral..
    Now finding a switch that's suitable and a suitable mounting point....that's the hard part.
  12. 283john
    283john
    I've got a 355/TH350 S-10 pickup that used to be a manual. I left the clutch pedal and switch in place. Still have to push it to start truck. kinda weird, but...hey.
  13. 325w
    325w
    Do what squrriel said. It's easy and works. Neutral safety on early powerglide 50-54 used a modified form of this switch. So did the backup lights.
  14. bct
    bct
    id agree with the mechanical switch over the hydraulic . more reliable
  15. town sedan
    town sedan
    If you do it, also install an over ride switch. I've cranked my way out of at least one intersection on the starter after stalling out. Can't do that with your foot pressing the clutch.
    -Dave
    chryslerfan55, seadog and Hnstray like this.
  16. Atwater Mike
    Atwater Mike
    I've had customers with clutch problems blocks from the shop, or 'stalled' in parking lots...
    Many's the time I started one up in 1st gear, upshifted, and drove it back to the shop with 'no clutch'.
    Two different times with Harley Davidsons that weren't mine, started them up, had 2 guys push me until I 'dropped it in gear', rode away praying for green lights all the way back...LOL
    If you know and understand the drive train's function, it's all relative. (tow truck bill $150 or drive it with one foot)
    A 'footnote' here: My O.T. '66 VW has a 'stiff' pressure plate, so I HATE cranking it cold with the clutch disengaged. No. 1 main bearing is the thrust, and cold cranking from 'dead' to initial startup raises Cain with that .200" X 6.25" bearing surface. I start in in neutral, clutch out. So, there may be controversy...
    I recall being surprised by a then new G.M. that had to be disengaged to crank the starter. Yep, I reasoned that it was a precaution for 'newby stickshift pilots'.
    chryslerfan55, egads and Hnstray like this.
  17. town sedan
    town sedan
    Had a couple old timers tell me that stepping on the clutch at start up will wear out the thrust bearing. All my pre safety cars I start in neutral.
    -Dave
  18. squirrel
    Using the clutch while driving will also wear out the thrust bearing. It's generally not a problem, because the rings wear out before the thrust bearing wears out. Unless something is wrong with the engine, or the clutch, or something.
    egads and VANDENPLAS like this.
  19. vtx1800
    vtx1800
    On my 53 Studebaker the starter switch was under the clutch pedal, not sure if that was a later innovation from your Studebaker but I think it would be easier to add a switch on the clutch than trying to figure out something on your shifter.
  20. Bleach
    Bleach
    I'm still trying to figure out how to get rid of the NSS on my OT F150. I never liked them on manuals.
  21. Hnstray
    Hnstray
    from Quincy, IL
    Worst of all systems....have to push 'fake' clutch pedal to start engine, which disengages nothing, and the auto trans can still be in any gear position on startup......:D
    Ray
  22. The 39 guy
    The 39 guy
    I installed this proximity switch on my 40 ford. The clutch pedal has to be in the proximity of the switch for the starter to engage. Works great.The switch came from McMaster Carr. IMG_9032R.jpg
    chryslerfan55 and txcr13 like this.
  23. Lone Star Mopar
    Lone Star Mopar
    Nothing like traditional hot rods, customs and nuetral safety switches .. ?
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
    Automotive Stud likes this.
  24. Bleach
    Bleach
    The simpler the better, less stuff to go wrong. Why bother.
    Before all this NSS stuff, I was always in the habit of jiggling the shifter before starting to make sure it was in neutral. I still do it.
  25. Deuces
    Deuces
    I once owned a 74 sedan DeVille that wouldn't start until you were buckled up.... Yeah, it pissed me off at times... :mad::rolleyes: But I got used to it...
    Atwater Mike likes this.
  26. finn
    finn
    They fixed it for you: Ford no longer offers a manual transmission F150.
    Problem solved!
    chryslerfan55 and Bleach like this.
  27. squirrel
    they got rid of that one real quick, the dealer would defeat it for you if you asked
  28. IIRC, when Detroit started installing these switches on the clutch one of the OEMs had issues with excessive thrust bearing wear (Olds? Can't remember now...). To be honest, my DD has this 'feature' and if there was a way to disconnect it I would, but it's interlocked with the computer somehow. I'm with Ned Ludd, I've had occasion to use the starter while in gear with clutch/linkage failures more than once, it got me home.
    They continually try to make driving idiot-proof, the easiest solution is don't let an idiot drive your car....
  29. squirrel
    They can't sell cars if they don't let idiots drive them.
    Torkwrench, mkebaird, egads and 6 others like this.
  30. Agreed, but I'd like to think the denizens here are smarter than that... LOL
    Ned Ludd and clem like this.
