Projects Need measurements for top mounts on A roadster
Discussion in 'The Hokey Ass Message Board' started by Mike Britton, May 26, 2009.
  1. I looked in search, I always ask the wrong questions.
    I'm opening the doors on my 'glass body '29 A, and I need to know how far back from the door opening the tabs for the top are.
    I can make the tabs from scratch and weld them to the 1" sq. that I'm using for support, but I want to make sure that the tabs are in the right place.
    Part of me says that I'll never run a top, and part of me realizes that these cars are never finished, get changed a lot in their lifetimes,and it would be a****** to put that tab in after the fact.
    I'm guessing that a piece of 1 1/2" x1/8" strap is about right, but I'd like to know how high, and how far back from the doors.
    Thanks guys.
  2. kenagain
    kenagain
    from so cal
    I measured my quarter panel it is back 3 1/4 to center 1 in wide 1 1/2 high has 3/8 square hole 1 in to center from bottom edge and is 1 in in from outside edge this is stock steel panel
    hope that helps
    Ken
  3. Thanks a million, Ken! That's exactly what I needed! Don't know that I'll use a top, but the brackets will be there if I do. Thanks again, Mike
