Need model A axle help.
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Aug 11, 2009.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Iv never delt with model A axles before, so id like to gather as much info as i can regarding mounts, angles, and more specifically, front brakes.
    Speedway makes a decent disk brake kit, but its for 37 ford spindles. Whats the difference?
    Id like to learn as much as i can about setting one up so i dont end up having to do it over.
    ~ Marty
  2. 55chevr
    55chevr
    37-41 spindles fit on Model A axle ... I have a set Speedways on my A axle now with F100 brakes ...
  3. carcrazyjohn
    carcrazyjohn
    from trevose pa
    So does 48 ford spindles Also you need radius rods same era 2 and 1/4 . 32 fords are 2 inch IM not sure about 34 . In the speedway catalog They will tell you how to measure for spring /I think that's all you need to know for buying parts. Also remember the magic number of 7 After you get the parts you need post how to set up front end.
  4. fordcragar
    fordcragar
    from Yakima WA.
    Correct me if I'm wrong, but I think that Model A and later use the same bearings; which would mean that that most of the spindle is at best similar. The later drums can be used on the Model A spindle. To put later backing plates on the Model A spindle you need the line up rings or spacers, so the backing plates are centered to the drum. The only other thing that I can think of is the Model A spindles have provisions for mechanical brakes.
    The later brake kits might not bolt to the Model A spindle.
  5. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    well, can i run the 37-48 disk brake setup on my 28-31 spindles, or are they different sizes?
  6. NYfatboy
    NYfatboy
    No,your spindles have a different bolt pattern (smaller) than the later spindles,you can make adapters out of 3/8" plate,thats what I ended up doing on my 36 ford.
  7. Ned Ludd
    Ned Ludd
    In other words, the actual spindle (stub axle) is the same (AFAIK), but the mounting for the brake backing plate differs. Early ones are round, later ones are squarish.
    By the way, and at the risk of hijacking the thread, can anyone give me some measurements of the spindle length, i.e. the inner bearing seating length, the length of the tapering bit, the outer bearing seating length, and the thread length? I'm trying to figure out how to run MGB knock-off hubs on early Ford spindles.
  8. Ned, I've got a model of a 37-40 spindle in Pro/E if you can use it.
  9. ltex old iron
    ltex old iron
    ive ran a set of speedway brakes and 37-41 spindles on two model a axles so far and worked well
  10. Ned Ludd
    Ned Ludd
    Thanks 413, can you export to .dxf/.dwg?
  11. I don't have access to actually use Pro/E at my current workplace. I do most of my work here out in the parking lot with sidewalk chalk. It is a .prt file if you can still use it.
  12. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    so couldnt you just re-drill the holes, and mount it that way?
  13. ablebob
    ablebob
    I just put gm rotors & calipers on a model "A" axle and used the "A" spindles. I made my own bearing adapters and modified some weld on caliper mounts. If you have a lathe, bandsaw & drill press it can be done. I have the numbers for the bearings & seals. I can take some photos tomorrow if your interested. I also have dimensions of the bearing adapters that I made. Bob
  14. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    please post all the info you can!
  15. Ned Ludd
    Ned Ludd
    Can't open it - but thanks.
  16. ablebob
    ablebob
    O.K. Here goes.
    Rotor from a 75 malibu
    Caliper from a 80 Monte Carlo
    Weld on style caliper bracket - speedway 916-41009 - cut about 1" off the "bracket axle ears" & drill holes to match spindle holes - make or buy washers to go between back of spindle & bracket - they will need to fit into the spot face holes.
    wheel bearing set #2 outer
    wheel bearing set #13 inner ( be sure to change the cup - they are not the same as the rotor)
    make a spacer for the bearing - see the drawing
    after mounting the rotor you need to drill a new cotter pin hole & maybe trim 1/4" off the end so the grease cap will fit.
    This gives you a 5X4-3/4" bolt pattern.
    If you want a small ford pattern there is a volare rotor that is supposed to work.
    Being a FNG I'm having trouble posting photos & drawing - I'll try to post them later. otherwise p.m. me.
    Bob
  17. ablebob
    ablebob
    Washers need to be 1/8" thick. Grease seal is from a 302 ford timing cover, Timken 2942.
  18. ablebob
    ablebob
  19. ablebob
    ablebob
    Disclaimer - try this at your own risk. I'm using it on a light car with skinny tires. Items I invent and build may self destruct without warning. Then again I have seen a broken anvil. Don't try this at home. Its all fun till somebody pokes a eye out. If you try to sue me you will only piss off your lawyer.
  20. If you do use the A spindles, you need to know that not all kingpins are created equal. I just rebuilt my A front end and swapped in '40 juicers, but kept the A spindles. I used '40 kingpins (Speedway Standard Kingpin set 910-32121) because they were cheaper and I no longer needed the Model A brake linkage. I ran into some trouble with the new pins. '40 spindles are wide enough top to bottom to get the bearing under the axle. Model A spindles don't have room for the bearing and leave it on top of the spindle, under the head of the kingpin. When using '40 kingpins with A spindles, you will need to re-knotch the kingpins where the lock pins engage them. The '40 knotches will be around 1/2 in. too high (the thichness of the bearing give or take the amount of wear on top of your spindles.) It is critical that these be machined in just the right place so that the weight of the axle hangs on the bearing. Luke
  21. ablebob
    ablebob
    Bumped to top so guy who PMed me can find it.
