Technical Need Model Number for Fuel Pump.
Discussion in 'The Hokey Ass Message Board' started by 1Nimrod, Nov 9, 2025.
  1. 1Nimrod
    1Nimrod
    Good Morning.
    This Fuel Pump is from my 1966 Chevy 327-300 HP engine.
    I'm looking for a Rebuild Kit that will work with today's Ethanol & other fuels I might have to use in the near future.
    I don't know the GM Part Number for this Fuel Pump.
    I've seen several different Part Number's for Fuel Pumps that look similar.
    I want to make sure I buy the correct Rebuild Kit the first time as they are over $100.+
    Thank you for your help.
    From
    Dustin
    (1Nimrod) 20251108_215627.jpg 20251108_215614.jpg 20251108_215607.jpg 20251108_215600.jpg 20251108_215546.jpg 20251108_215533.jpg 20251108_215654.jpg 20251108_215636.jpg
    Just Gary likes this.
  2. BJR
    BJR
    Clean it off really good and there should be a number stamped on it. Usually on the sides of the mounting flange. Give that number to the place that has the rebuild kit, and they should be able to get you the correct kit.
    X-cpe, Squablow and 1Nimrod like this.
  3. 1Nimrod
    1Nimrod
    20251108_215614.jpg This part of the Mounting Flange that's inside the red circle?
    Thank You BJR.
    Dustin
  4. partssaloon
    partssaloon
  5. 1Nimrod
    1Nimrod
    Thank You...
    Dustin
  6. RodStRace
    RodStRace
    @BJR I think it might be on the lower flange, opposite the Made In USA shown, which is also where the IN and OUT are cast.
    A through cleaning should find it. Good luck.
    This ad at least shows the common numbers although it's not in stock. You will need to determine if it's GM or Carter.
    https://www.ebay.com/itm/266068910224
    1Nimrod likes this.
  7. squirrel
    What is the engine going into? I'd get the pump for that....so the lines will be in the right places.
    Some small block Chevy applications need a pump with the lines in a special place, others are not so picky. If I could use a pump that is available at any parts store, that's the one I'd choose.
    Using a pump that needs to be rebuilt has been the wrong path to go down for me....I've been through that on a variety of old cars recently, and generally end up running an electric pump to keep the car running under all conditions.
    good luck.
    winduptoy, 1Nimrod and RodStRace like this.
  8. 1Nimrod
    1Nimrod
    Thank y'all very much I appreciate your help.
    Dustin
  9. RodStRace
    RodStRace
    Yep, I thought Hmm, HP and rebuildable, great! OT mopar.
    Then the inlet/outlet didn't align at all and clocking it didn't fix it.
    Since OP doesn't have the original, they will have to go with the one called for, but unless they go with OG resto part # and have the OE line to carb, it's a toss up if the parts store cross reference is exactly right or just a supersede = one size 'fits' all.
  10. 1Nimrod
    1Nimrod
    For my 63 C10 Pickup, sorry I forgot to write that.
    Dustin
  11. squirrel
    The pump you have is likely for a different vehicle, so you really want to start with a pump that is designed to fit your truck.
    There have been a bunch of different small block pumps made over the decades to fit different cars and trucks. Trying to use the wrong one just leads to trouble.
    HemiDeuce likes this.
  12. 1Nimrod
    1Nimrod
    Resized_1762734070754_126753266460991.jpeg This Carter Fuel Pump below is Ethanol compliant and it looks alot like the Fuel Pump I already own, a bit different on the bottom mine having two screws and this Carter one I believe. Seems to be the one I need, I thank y'all for your help and pointing me in the right direction.
    Dustin
    Carter Mechanical Fuel Pump 327/348 Chevy C10/K10 60-66
    https://share.googley/wuXao405FP7D4J2KM
  13. squirrel
    All of the ones made today are ethanol compatible, but all of them will suffer if you leave them sitting unused for years with fuel in them. You just gotta drive them.
    Make sure the housing is pointed the right way so the hoses on the truck will reach it. Some vehicles are not too picky, but the 327 in my 62 Corvette is in there pretty tight, and needs just the right pump.
    partssaloon likes this.
  14. 1Nimrod
    1Nimrod
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    1Nimrod likes this.
  16. squirrel
    that's probably supposed to go to a big fitting on top of the water pump.
  17. 1Nimrod
    1Nimrod
    If I remember correctly that double water inlet was used on the Big C30's and up, reminds me of how the C10's had the first 292 in 63, the 292 had that extra coolant line off the water pump on the driverside back into the top, my 63 292 engine extra coolant line was plugged off and used for a water temperature probe on top and the other end plugged with a air valve to help burp the air out of the coolant system.
    Missouri Farmer engineering at its best, all Farmer's make do with what they have on hand that's how I was tought when growing up working on our Farm.
    Dustin
    Fordors and Toms Dogs like this.
  18. Toms Dogs
    Toms Dogs
    from NJ
  19. 1Nimrod
    1Nimrod
    Crumb's Zap Comix. Folks had that sticker on Lots of Off Topic Vans, Truck's and Car's. Bringing back lot's of memories also Kendrick Song.
    My Yellow 2 dr Hardtop Off Topic Chevy II had Black Keep On Trucking stickers on its rear quarter panels. Thanks Toms Dogs for bringing back those locked away memories, its the second time in a few months "Keep On Trucking" has been mentioned.
    Dustin
  20. RodStRace
    RodStRace
  21. 1Nimrod
    1Nimrod
  22. RodStRace
    RodStRace
    If the link didn't work for you, hover your pointer over the picture on the left above their name.
    It should show their posts, like this
    If you click on those A LOT are the same picture.
  23. 1Nimrod
    1Nimrod
    Thank you ...
    Dustin
    RodStRace likes this.
