Technical Need more brake help.
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Dec 26, 2025.
  1. rusty rocket
    rusty rocket
    So I had post earlier about not getting pedal even after bleeding brakes. So the consensus was I didn’t bench bleed it and that was the problem. I took the master off and bled and now I have pedal. Now when I push the brakes the power ***ist pedal goes down and stays down. The motor is a blueprint 383 with a healthy cam. Do I need to get a vacuum canister to get enough vacuum for the booster?
  2. NoelC
    NoelC
    Isn't that something? 54 looked and no reply? I'm going to say no.
    50% chance I'm right.
  3. miker98038
    miker98038
    The pedal usually comes back up with the engine off. So I doubt it’s a lack of vacuum. More likely a fault in the booster. I guess I’m ***uming the pedal has a return spring.
  4. hrm2k
    hrm2k
    There is a rod between the master cylinder and the booster. Have you tried adjusting the rod either way ?
  5. rusty rocket
    rusty rocket
    Yep
    hrm2k likes this.
  6. If you're in a big hurry and don't want to run diagnostics, gamble whatever it costs for the vacuum cannister and maybe you'll get lucky. If you're wrong, start the long process.
    mad mikey and Happydaze like this.
