Need paint help?!!!!!
Discussion in 'The Hokey Ass Message Board' started by Flattop, Jul 22, 2007.
  1. Flattop
    Flattop
    Does anyone know what mixing ratios are used with the PPG DP epoxy primers? Do these use a hardener or is everything included in the reducer/catalyst?
    Thanks,
    Flattop
  2. SpeedRacer2002
    SpeedRacer2002
    been a while but 4:1 seems right and your catalyst is your hardner
  3. jusjunk
    jusjunk
    from Michigan
    Ever try google? all the info is online. I just dont have the link handy here at work..
    Dave
  4. CMenard
    CMenard
    4:1 with the catalyst. I spray it 4:1:1/2 part DT reducer.
  5. Flattop
    Flattop
    Many thanks!
    Flattop
  6. LUCIFR
    LUCIFR
    from Seattle
  7. SlowandLow63
    SlowandLow63
    from Central NJ
    Ditto ^^^ You can always check PPG's tech sheets at PPG.com They'll give you mixing ratios, proper substrates, flash times, etc. Basically whatever you need. I printed out the ones I use the most and keep them in a binder with the rest of mine.
  8. I hope you didn't shoot your car yet. The mix is 2 to 1 not 4 to one. 2:1:1/2 if you want to use it as a sealer. It needs a 30 min dwell time if you use the 401 catalyst. If you don't have a P sheet, you might want to look at the side of the can.
  9. Sam F.
    Sam F.
    yes!
    http://www.ppg.com/cr-refinish/phase1/frmProductInfo.asp
    type what ever product you are using in the box to the left,,,all your online P sheets ,,print hem out,,share with a friend :D
  10. Flattop
    Flattop
    I was able to get in touch with a PPG distributor who told me to go with the 2:1 ratio. I have had this stuff for about 4 years now and had long ago lost the tech sheet. I appreciate everyones' responding.
    Thanks,
    Flattop
  11. Sam F.
    Sam F.
    well,,,i hope your cataliyst has never been opened,,,,because if it has then its gone bad,,,,
  12. LUCIFR
    LUCIFR
    from Seattle
    I beleive the 2:1 ratio is for a real fast flash off?? if thats what you are looking for??
  13. Sam F.
    Sam F.
    dude.the ratio is 2:1....thats what it is...
  14. prl98
    prl98
    is dp or dplf? the mix ratio is different. dplf is 2:1. the old dp is 1:1. If you want to use as asealer then you would mix dplf at 2:1:1, and dp at 1:1:1/2
  15. Sam F.
    Sam F.
    you can still get DP in california???
    thats wild,,,cant even get it here in kentucky and cali's regulations are the reason for dpLF (lead free)....
