I need a picture of the bracket that the B pillar sits in at the sub rail on a stock 34 3W. I am putting together a stock eight 3W using SAR body parts. My other chopped 3W has Don Smart steel B pillars so I have nothing to go by. Looking for a set of wood B pillars and the above door wood headers as well. Thanks Dan
Are you wanting to build your own wood pieces or will you be using parts from a vendor? I was just thinking that if you used pre-cut pieces, they would come ready to install, giving you a shape to work with. I only assume they have that much detail.
I will be using vendor wood but would like the brackets (sockets?) as original as possible if not actually original parts. I had to wing it on several issues with my avatar car because I didn't have anything true to work from. This car needs to be different. It will be my 4th 34 3W and the first to be stockish and un-chopped. Thanks
I would like to see these brackets too as im putting the same thing together. I plan on making the wood b posts and above the door wood it will help if i had a pattern to go off of.
