Need pics of Model A's sedans fenderless on stock rails
Discussion in 'The Hokey Ass Message Board' started by grego31, Dec 4, 2009.
  1. grego31
    grego31
    from Sac, CA
    So as the title says, I am looking for some inspiration for a new project and need some pictures of a fenderless Model A's sedans on stock rails, channelled or not, prefer then not since I wont be doing that right now.
    Nothing too slammed and in the weeds, not the look that I am going for. Maybe a little Z'ed in the back for the proper stance.
    Thanks all.
  2. TOE
    TOE
  3. grego31
    grego31
    from Sac, CA
    cool thanks for the link, let me narrow it down then to sedans on stock rails
  4. 32gal
    32gal
    from The OC
    Heres Cruzr's car its on A rails
  5. 1930roadster
    1930roadster
    I have a 29 i'm just starting on, you sound like me... Every time i look, 32 rails, which is why i'm using my stock frame boxed and a 4-6" z in rear, i want to keep the rumble seat as well, of course no fenders... i hate going mainstream, just me, good luck
  6. grego31
    grego31
    from Sac, CA
    Thanks, I am trying to keep it low cost and trying to do more of my own fab work.
    As for mainstream, don't even get me started on my engine choice.
  7. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    Here is 73roundlight's ride
  8. Velocette
    Velocette
    from Finland
    Mechanical...
  9. motoandy
    motoandy
    from MB, SC
    Main computer is down.Just have my avatar to look at.Some pics in my album
  10. grego31
    grego31
    from Sac, CA
    Any other pics?
  11. stillkruzn
    stillkruzn
    from Conway, AR
    Here is my sedan...
  12. BeatnikPirate
    BeatnikPirate
    from Media, Pa.
    Here's mine.
  13. BeatnikPirate
    BeatnikPirate
    from Media, Pa.
    Here's two that I like, seen at Macungie and Vargo in Pennsylvania.
  14. captmullette
    captmullette
    my 31 drag/hotrod
  15. Dirt Dobber
    Dirt Dobber
    here's my project, I ran a spring behind axle front and rear with t springs in rear. Still need to channel body once top is welded back together.
      437.2 KB
  16. BeatnikPirate
    BeatnikPirate
    from Media, Pa.
    Two more from Penna.
  17. BeatnikPirate
    BeatnikPirate
    from Media, Pa.
    One of my favorites, at the top of the page. Saw it in SRM. To me the proportions look just right.. I'm guessing maybe a 3 to 4 inch chop and 3 to 4 inch channel. Not sure....but I like it.
  18. HotRodFreak
    HotRodFreak
    I sold this one already but it is a 29 two door tub on stock frame after whacking top.
  19. Any more pics? thanks!!!
  20. choppedtudor
    choppedtudor
    after a 7 1/2 chop
      107.3 KB
  21. Here is mine. I took them off to do some body work. I'm going to run without for awhile. Still need to lower the ass end some.
  22. What is the best way to lower the rear SOME and maintain a rear seat? I have an original rear seat, a stock rear floor pan etc to work with (and I'm not afraid to cut it!). How much to I expect to loose by a reverse eye spring? What about a spring behind set up? Can I modify the spring by moving leaves around and not bottom out with people in the back?
    Most write ups on this are a coupe/roadster with no people in the back, and a frame that is rasied into the trunk.
    My original plan is to step the frame a frame width, reverse eye spring, and loose a leaf or two. I would like to hear or see what you guys have done.
    Here is a couple of my car mocked up in the driveway.
  23. pasadenahotrod
    pasadenahotrod
    from Texas
    You can reduce the number of leaves in the front spring to 6 or 7 rather than the stock 10 or 12. And a like number in the rear. Keep the 2nd leaf(the one that sits on the main leaf) and take out the odd numbered ones, reassemble, check for ride and "bottoming", dismantle and add in a long one and a shorter top one, and try again. You willl need to make a spacer under the spring so the clamp bars will still seat and keep it tight in the crossmember.
    For visual lowering put the runningboard aprons back on, and make up supports for them to bolt to the frame through the runningboard support bracket holes in the frame. For 1930 cars with one-piece apron/runningboards with nose of apron spotwelded to front fenders use full length 31 aprons.
  24. Retroline
    Retroline
    This photo has been flogged to death, but what the hell.
  25. Framewelder
    Framewelder
    Here are a couple we did for local customers.
  26. A 1928 built by Frank Salisbury of upstate New York.
    Frank has more talent in his little finger than I have in my entire body and mind.
    One look at his car and I had to open my wallet. If you cant build it right, have a talented guy like Frank get 'er done!
  27. olfogey54
    olfogey54
    Here's my 29
