Yeah, yeah, I got Mopar **** on my car. No comments from Hellfish... Or at least I would have if I could figure out how to modify or make a bracket. Hell, I'd even just buy one if it existed, cause that is one of many "small projects" that could potentially keep my car from it's maiden voyage to Memphis in April. So any suggestions on how to make this work? Here are the particulars... The pump and rack are off a K-Car. Motor is a 289. I could buy a manual rack, but that is money that I don't have right now.
no comments? None? I still think you should've stuck with the 37 frame, but you said "no comments" So neither a Ford nor a Kcar bracket will work? Not even modified?
I'm saving the '37 ch***is for a more pure, pre '48 parts type roadster project. This way my car will be done BEFORE your, AND it will easily kick your car's ***, any time, anyplace. The ford bracket just isn't going to work. It may be easier to start from scratch, but this kind of fab work is beyond my abilities I think...
I would need to see a little bit more to know what you are up against. I made a bracket to mount a Chevy pump on a 351W and that seems to work just fine.( Camaro clip in a '60 Ford truck ) Some people said I should use the Ford pump and have custom lines made, but I was not sure if the pump pressures were the same. Besides, making my own bracket was cheaper for me than buying a custom line...
