Need quick help with stuck brake rotor !!!!!!!!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by Darkman270, Sep 4, 2003.
  1. Darkman270
    Darkman270
    My son has a 91 Buick Century and can't get the rotor off. He has the caliper off and has cleaned the hub area in the center but it will not budge. Any and all ideas are welcome. I'm not much help as I have only Fords. It looks like it should come off but it won't. Is there a special puller for this?
    Many thanks,
    Charles in Pensacola
  2. SKR8PN
    SKR8PN
    BFH......It is rusted to the hub. Wail it a time or two,it'll come off. Please don't tell me you are doing a "one wheel brake job".........Tell me you ARE going to do BOTH rotors.........the life you save may be MINE [​IMG]
  3. Fat Hack
    Fat Hack
    from Detroit
    Oh, they can and will seize on the hub pretty good sometimes! (If it is the kind that simply slips over the hub and lug studs). I've had to actually cut or torch them off before!
    I don't know how your particular car is configured, but inspect the hub closely. It may require that you remove the kotter pin and nut at the center of the hub to remove the rotor. Most front-drivers I've encountered use a "slip on" style of rotor held in place by the caliper and the wheel, but they can be a real nightmare to get off in some cases, as I said! Before you break out the big sledgehammer, torch, prybar and hand grenades, consult a repair manual or someone who knows your type of car to see if there isn't anything else holding it on!
  4. Darkman270
    Darkman270
    Thanks for the quick reply. Yes we are doing both but both are stuck. He was told by mechanics that it just slips off. We have been tapping but may resort to wailing shortly.
  5. CLSSY56
    CLSSY56
    That happened to me with my Jeep I had. I wailed on it with a hammer with no luck. I ended up using a Hi-Lift jack to pry them both off the rear. It worked.
  6. SKR8PN
    SKR8PN
    If they are stuck so bad they won't come off with a tap or two,your prolly gonna need new ones any way,so don't be nice to them...........and yes,those ARE the slip on kind......try to avoid using heat if at all possible.It's real easy to get carried away and damage the seals in the wheel bearings.
  7. Darkman270
    Darkman270
    Thanks guys I guess will get out the crow bars next. Wailing doen't seem to help. LOL
  8. CLSSY56
    CLSSY56
    BIGGER HAMMER???????
  9. gregg
    gregg
    from Fulton IL
    We see this all the time at the shop. If you wail on them too much you're gonna bend the hub. Attack it with a sawzall & then hammer it. New rotors are cheap.
  10. smoked1
    smoked1
    Sawzall !cut it into pieces then wail with a BFH. carry on.
  11. alchemy
    alchemy
    HA! You brought up an eleven year old post about a '91 Buick! Cl***ic.
  12. kidcampbell71
    kidcampbell71
    Yes......BUT is it still stuck ?? lol :confused:
  13. seb fontana
    seb fontana
    from ct
    Is this a record for oldest bumped post? Cool!
  14. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Im hoping by now he has it fixed. Hell, this much time its almost a traditional car :cool:
    kidcampbell71 likes this.
  15. 59Apachegail
    59Apachegail
    from New York
    Poor guy still has that thing up on blocks... It must be rusted more solid than the tin man. He hasn't posted since.
  16. zipoleon
    zipoleon
    Now I'll be awake all night, wondering if he ever got it off.
  17. tb33anda3rd
    tb33anda3rd
    i'm sure it was fixed, and if it is still on the road, is driving around florida below the speed limit, in the p***ing lane with the left turn signal on, dragging the p***enger seat belt that is caught in the door.
    prewarcars4me likes this.
  18. Them 91buicks are tricky rascals. 11years sounds about right.
    Way to go smoked1, whatcha smoking
