1952-59 Ford Need Rear End Gear
Discussion in 'Off Topic Hot Rods & Customs' started by rustyfords, Sep 12, 2015.
  1. rustyfords
    rustyfords
    from Conroe, TX
    It looks like the rear end gear in my 2 door sedan is toast.
    Anyone have a good set they'd let go of?
  2. Alan Freeman
    Alan Freeman
    Hi Don. What gear ratio are you looking for? Alan S. Freeman
  3. rustyfords
    rustyfords
    from Conroe, TX
    I'm not that particular Alan but I guess I need to check and see what ratio is in my tudor now. Whatever it is, I like the way it's working with my 302/AOD swap. So....something close to what I have now would be ideal.
    Is there a gear ratio identifier on these rear ends?
    I'll almost certainly do the 90-92 Ford Ranger 8.8 upgrade that Jeff talks about...but for right now, I'm inclined to go with the quick fix...just a quick swap-out of another set of stock 54 Ford gears. (if I can find another set).
  4. Dobie Gillis
    Dobie Gillis
    If was originally equipped with a straight 3 speed the axle ratio is 3.90:1; 3 speed with OD had a 4.10. If it had a Fordomatic originally it will have a 3.31:1 ****. This is all contingent on the probablity that a previous owner didn't swap axles/transmissions.
  5. rustyfords
    rustyfords
    from Conroe, TX
    Thanks for the info. My car came with a 3 speed and no overdrive. So, it looks like I have a 3.90:1 gear. (I bought the car nearly 30 years ago with just over 10K miles on it, so I'm 99% sure that it's original)
    It's working well with my AOD....just making a lot of noise.
    I'm thinking another set of 3.90's or even 4.10's would work well with my setup.
  6. Dobie Gillis
    Dobie Gillis
    Check with Joblot Automotive. He has a lot of hard to find hard parts including some parts for your axle. They have an online catalog but you have to call/fax/snail mail an order.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Don, 1954 Fords with 3 speed transmissions came with a 3.09 gear,while cars with overdrive had a 4.10 to 1 ratio and the Ford-O-Matic came with 3.31 to 1 gears. HRP
  8. rustyfords
    rustyfords
    from Conroe, TX
    JeffB saved my bacon again.
    He suggested that the large nut on the yoke might be loose.
    I jacked up the rear end and had my son step on the brakes while i torqued the nut on the yoke. It was loose. I immediately took it out for a spin and 95% of the gear noise was gone. I can still hear it ever so slightly but that may be me being too sensitive...plus theres no interior, sound deadener or carpet in the car to cut down on noises.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Glad it worked out for you,it is something to check on the stock rears if it's not be re-torqued it can damage the pinion bearing hopefully it was caught in time.
  10. HOTRODPRIMER
    HOTRODPRIMER
    I've noticed time & time again Jeff is a walking,talking Encyclopedia of knowledge,both here and over on the '54 Ford Club of America site.
    Jeff and I don't always agree on cooling issues but I have immense respect for him and what he has to say,I read all his post. HRP
  11. rustyfords
    rustyfords
    from Conroe, TX
    It was quiet on acceleration and then noisy when I let of the gas. In my amateur opinion, that seemed to suggest something loose, and not necessarily damaged gears.
    Time (and my first, full speed highway run) will tell if there's any damage.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Don,have you replaced the universal joints? HRP
  13. rustyfords
    rustyfords
    from Conroe, TX
    Yes....front and rear
  14. JeffB2
    JeffB2
    from Phoenix,AZ
  15. rustyfords
    rustyfords
    from Conroe, TX
    Probably wouldn't hurt to replace it. Would I get at it by removing the nut in question?
  16. JeffB2
    JeffB2
    from Phoenix,AZ
  17. rustyfords
    rustyfords
    from Conroe, TX
    I own it Jeff...I'll take a look at it.
