Hot Rods Need seals for GM 8.2 drop out rear end 1959 era but cannot figure out what I have.
Discussion in 'The Hokey Ass Message Board' started by Kit-T, Sep 16, 2023.
Tags:
  1. Kit-T
    Kit-T
    Refinished the rear end of my Instant T but all the numbers have been previously buffed off. Casting cover on the comes out to December 28 1959. I need bearings and seals but the Chevy ones show 3 inch diameter. I only have 2.750 . All the Chevy ones I see listed are 3 inch . Can anyone tell me what I have and what I need?
  2. 427 sleeper
    427 sleeper
    Didn't the 55/6 housing's use the smaller axle bearing's? 57 and up were bigger.
    Don't worry about the date on the Pumpkin, they'll fit anything from 55 to 64.
    Try looking for 55/6 axle bearing's.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Does the housing have a drain plug? If not it is a 55 or 56. 57 was the first year for a drain plug in the housing
  4. Kit-T
    Kit-T
    Housing does have a drain plug. Hard to see in the picture
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Are there no numbers on the old bearings?
    427 sleeper likes this.
  6. 427 sleeper
    427 sleeper
    Drain plug's can be added easier than swapping housing ends... ;)
    scotty t and Moriarity like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
  8. Kit-T
    Kit-T
    I took the bearing to a machine shop to remove them and could see no numbers. I should have looked closer before they were destroyed in removal.
    427 sleeper and SS327 like this.
  9. 427 sleeper
    427 sleeper
    What axle bearing's did the early Chevy II's use, big or small?
  10. Kit-T
    Kit-T
    On closer look I just have the fill hole. They drain plug appears to added with an Allen screw later. 100_0260.JPG 100_0261.JPG
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I thought about that too, rock auto lists those at only 2.25”
  12. 427 sleeper
    427 sleeper
    Welp... that's more than I could find on them. LOL!!!
    Moriarity likes this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
  14. Lloyd's paint & glass
    Sounds to me like he has a 55 housing that somebody added an Allen head drain plug to, that has a 59 center section?
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    Seems so, but he said his ends measure 2.75 and according to rock auto the 55,56 bearing measures 2.83
    Lloyd's paint & glass likes this.
  16. 427 sleeper
    427 sleeper
    That could be the difference between a dial caliper and a worn out tape measure... ;)
  17. Kit-T
    Kit-T
    On the outside of the hosing is about 2.82 but further in is 2.75". Im not sure where the correct place is to measure. . Thanks for all the replies.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    the closest to the outside. this is where the bearing sits. sounds like you have a 55 housing rear.JPG
    jimmy six and 427 sleeper like this.
  19. brading
    brading
  20. jimvette59
    jimvette59
    I think the 57 has the O rings on the bearing no seal. One year only . Looked on Summet I did see the wheel bearing with one O ring. If I remember 57 has a different axle also. I sold a set a while ago and have the center section in my 59 Corvette. Getting old is not easy.
