Technical Need shoebox hood hinge picks
Discussion in 'Traditional Customs' started by atmospheretattoos, Jun 9, 2014.
  1. atmospheretattoos
    atmospheretattoos
    from London Ky
    I juat recently picked up a 49 shoebox for the life of me I can't figure how to mount the hood to the hinges. Can someone take a ckoseup pic or too of a functional hood
  2. There are special bolts that go through hinge into hood . Jim carter sells them and so does shoebox central !
  3. happy hoppy
    happy hoppy
    hope this helps
  4. atmospheretattoos
    atmospheretattoos
    from London Ky
    Mine dont line up for those bolts. And my brackets are diff so im at a loss
  5. atmospheretattoos
    atmospheretattoos
    from London Ky
    Oh and thanks for the supplies fellas
  6. seb fontana
    seb fontana
    from ct
    I think the 49' hinge is different from a 50'/51', though the shoulder bolts are probably the same..
  7. 49ers had bad hinges and a weak hood brace to bolt them to. Doors latches suck as well. Not sure if you can add 50 hinges and brace to the 49 hood. Doors your screwed as they are different in the latch assy.
  8. atmospheretattoos
    atmospheretattoos
    from London Ky
    Probably why im losing my mind lol wonder if the hood I have is from a 50+ and wont work ugh
  9. atmospheretattoos
    atmospheretattoos
    from London Ky
  10. You can use inside of hood brace and hinges from a 1950-51 on a 49 hood !! If you want to know what the difference in hinges look like go to shoebox central they have pics of hinges . Hope this helps
  11. atmospheretattoos
    atmospheretattoos
    from London Ky
    Thanks dozzee but we just had a bad storm took my fence and hood so .. ugh
  12. dan c
    dan c
    that's right about the 49 hood--it's bad news. check out the scene in "thunder road" where the mitchums are prepping the "50" for a run. that car had a 9 year old '49 hood on it and it already was doing the el-foldo on the right rear corner!
  13. The photo from Happy Hoppy is of a 1950 Hood and hinges. Totally different. You have a 50 Hood in your photos and 49 hinges. They will NOT work as a system. You need a 49 Hood or 50 hinges to get the hood mounted on your project.
    49 Ford Coupe just went through all this.
    The Wizzard
  14. Yes I did. Good to see your project coming to an end. Well done.
    The Wizzard
  15. F.Y.I. When shopping for a hood, if your unsure of what your looking at or being told by the seller. 1949 Hood had 4 individual block letters spelling FORD on the front of the hood. 1950 hood just had the Ford Badge on center mounted with 2 quarter inch studs. No letters at all.
    The Wizzard
