Need Single brake line diagram
Discussion in 'The Hokey Ass Message Board' started by Chopperman, Mar 19, 2007.
  1. Chopperman
    Chopperman
    disc fronts
    drum rears
    single line wilwood master
    prop valve
    thanks
  2. squirrel
    master cylinder connects to tee
    one side of tee to another tee, that goes to both front brakes
    other side of first tee goes to prop valve, then to another tee that goes to both rear brakes
  3. swade41
    swade41
    from Buffalo,NY
    Look in a Speedway mag, they have a diagram in there.
    just use a T to split the front and rear,
  4. chaddilac
    chaddilac
    You don't need a proportioning valve for full drum brakes do you?? Only for disc and drums combo?? right?
  5. AstroZombie
    AstroZombie
    from Marina, CA
  6. AstroZombie
    AstroZombie
    from Marina, CA
    ****, you said single pot (sorry).......ok, go with what squirrel said, he's always right anyway!
  7. ACECHEV55
    ACECHEV55
    OK I'll ask its looks like you do nice work [ check out you pictures ]
    why don't you use a dual master cylinder??? sure would be a lot safer.
    Acechev55
