Hot Rods NEED SOME ADVISE
Discussion in 'The Hokey Ass Message Board' started by Todd's Rod's, May 10, 2017.
  1. Todd's Rod's
    Todd's Rod's
    from MInnesota
    I need to radius the rear wheel wells on my 57 Ranchero g***er. So the question is because of the shape of the rear wheel housing what do you recommend? I want to run a slightly reversed wheel and a 10 inch slick ;wheels will be 8.5 inches wide. If you have done one and have pictures please share. Thank you IMG_0691 (1).JPG
    57Custom300 likes this.
  2. I did one back before the day of Digi camera's so no photos. What I did was cut above the Factory reveal and took a section out of the flat section of the Quarter. Then hand built the bottom front corner to remove the slight hook. Here are some photos of kind of the same treatment on a little newer car not H.A.M.B. friendly. Photos are just for a reference.
    You can see the ridge here just above the wheel opening and extends to the door opening. I kept that accent line much like you have on your 57 and just moved it up.
    Here is what it looked like while in progress.
    And here is the end result. Not much to it really.
    Well worth the effort to keep the factory accent lines. The 57 Ford really doesn't do well just making a round hole around the tire.
    If interested I can tell you how to put a 12" wide tire under a 57 without cutting any body sheetmetal or modifying the Frame rails and not go outside the body panel. You could sit it on the ground or go Sky High.
    The Wizzard
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There's the cut and go approach. [​IMG]
    Todd's Rod's likes this.
  4. And there is why I do things the way I do them. Not that there is anything wrong there, I just can't do it that way.
    The Wizzard
    Chucky and Hatchet like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Don't get me wrong. There's cut then there's cut but in the theme of things a clean cut is all that's needed to be a G***er. They were not meant to be perfect but I do appreciate good metal work when it's warranted.
  6. Also, so you know there is a piece of 1/2" X 1" .065 Rectangle tube welded into the body panel so it isn't a Flexi Flyer and or a sharp edge for opening your hand, arm or a very expensive Tire.
    The Wizzard
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    1/2" steel tubing or 1/4" steel rod for G***er's ;)
  8. Hnstray
    Hnstray
    from Quincy, IL
    My thought, were I doing this project, would be to entirely remove the shaped section of the lower rear quarter and replace it with a new panel made to fit. There may even be a readily available 'patch panel' from another make or model that would be a good fit with minor tweaking. Further, in my opinion, the new, rounded wheel opening would look best with a flared edge.
    Ray
    Stu D Baker likes this.
  9. selohssa
    selohssa
    I did mine by 90 degree bending some 20ga so that it was 3/4"x1/2" and several feet long. I then used a stretcher to give it the radius that I wanted. next, I marked it on the quarter, allowed for enough material to be bent out for the flare and then trimmed the quarter. once it was welded and ground, it is very similar to a factory arch with the same lip.
    IMG_0934.JPG IMG_0935.JPG IMG_0936.JPG IMG_0939.JPG IMG_0981.JPG IMG_0729.JPG IMG_0725.JPG
  10. Nicely done, well executed, I could live with that. Good eye appeal as well.
    The Wizzard
    DFH-GMC and Hnstray like this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Another true to style [​IMG]
  12. slowmotion
    slowmotion
    Here's one I always thought was done right. It's here on the Hamb someplace:
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    From another thread [​IMG]
