Technical Need some carter afb help
Discussion in 'Traditional Hot Rods' started by texas56, Sep 23, 2013.
  1. texas56
    texas56
    Hello all, wanted to see if anyone could tell me what is causing my issue. I have a 671 blown sbc that has dual afbs. Has good fuel pressure, runs good, and idles good. Sometimes when you get on it hard, as you are coming to a stop or turning a corner, it tends to die. Like it runs out of gas but ii think it is flooding because if you pull over, hold it to the floor it fire right back up. Thanks for any help you guys can give me.
  2. squirrel
    Maybe put it in neutral, and goose the throttle a bit when you come to a stop or go around a corner.
    You could make sure it has a good filter, there's no crap in the needle/seats, the floats are properly adjusted, and there is nothing causing too much fuel pressure, too.
    Hot rods are fun!
  3. King Callie
    King Callie
    from Virginia
    I am not certain of all the details but I seem to remember hearing that blowers can cause either the actuators or power valves in the carter carbs to act up. Not much to go on but maybe it gets you headed in the right direction.
  4. Slimmey
    Slimmey
    I have the same problem with my 2x4 '58 vette. Talked to my uncle a while back. Mainly stop to fast or when turning left hard. He found his notes from 1962. I believe he said it was vent tubes pluged. I just called him as I never got around to fixing, this (reminded me), he couldn't remember either. Said he would dig out his notes tomorrow. Said it was common though.
  5. texas56
    texas56
    Awesome I'll take any help I can get! Much appreciated!
  6. landseaandair
    landseaandair
    from phoenix
    My buddies T was doing that a few years ago. Pretty sure I fixed it by setting the floats properly?
  7. Slimmey
    Slimmey
    Texas, my uncle informed me my carbs are wcfb's (don't know what i was thinking) with the vent tube problem, not the afb. Sorry about that. He did say the afb's sometimes just had a float set problem. He said make sure they were not fuel soaked (solid) or pin hole (copper type). Said he preffered afb.
  8. Slimmey
    Slimmey
  9. BLAKE
    BLAKE
    Two things come to mind - float level, or vapor lock. You running an electric fuel pump?Does it happen primarily when the motor and weather are hot? If not, can you reproduce it just by stopping or turning hard while rolling at idle?
    My twin Carters were really heat sensitive until I installed the laminate spacers and insulated the fuel line... all good now.
  10. Bert Kollar
    Bert Kollar
    I raced an AFB in an autocross car for several years, very hard turns. The problem with non vented AFB's is they dump fuel over the bowl. The cure was to provide vent tubes for the fuel to go in and return to the bowl. I also epoxied the runner between the bowls and in effect created two separate carbs
  11. DS1937
    DS1937
    Drop the float level, easy enough to try.
  12. models916
    models916
    Set the floats correctly with a drill bit of the correct size for the rise and fall of the float. Then install the Off Road needle and seat from Edelbrock. It's spring loaded and much less sensitive to changing conditions.
  13. 56sedandelivery
    56sedandelivery
    I believe there are three adjustment holes in the accelerator pump plunger arm, each gives a different sized "squirt" of fuel. I bought a new 1970 340 Dart that had a similar stumbling problem from the factory, and only on those with an automatic transmission. I don't remember the specific fix,as I swapped to a Holley shortly after I bought the car. I did get a re-call type notice at the time. Maybe an old MOPAR mechanic, or someone with the factory-to-dealer service bulletins can help. Butch/56sedandelivery.
  14. texas56
    texas56
    Thanks guys for all the help and advice! Ill try all of them!
