need some early Ford steering box help.
Discussion in 'The Hokey Ass Message Board' started by lowsquire, Oct 19, 2010.
  1. lowsquire
    lowsquire
    from Austin, TX
    Hi all,
    Rebuilding a 34 (i think) steering box to go into a 33 pickup ch***is, I ordered all the rebuild parts from Macs, everything is spot on, except the upper bearing cup. Macs lists the same upper and lower bearing, but they are clearly different in this steering box.
    The lower cup Ford No. is B-3552, and macs supplied this for the upper also..its too small in the OD.see pics.
    But the original cup has B-3553 as a part no. Macs does not list this number, and I am having trouble finding this number on any online early ford parts suppliers websites.
    I went to the local bearing joint, and according to him the Timken No. for this bearing is 06. No one I can find in australia has this Timken bearing cup.
    does anyone know who can supply me this Damn thing??
  2. CBC bearings 9561 6400 Notting Hill. They always have what I need or get it in 2 days.
  3. lowsquire
    lowsquire
    from Austin, TX
    Thanks man,
    have CBC heidelberg west on the case already..no luck sofar.
    Timken 06
    thats all its called...rang ten different bearing shops in melbs already..none showed any stock in australia. boo.
  4. jetmek
    jetmek
    i have it as type TSG series 5BC for some reason i have #7 marked as upper race but there is an 06 listed also .the print is so bad i cant read the dims off it
  5. mj40's
    mj40's
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    Turn up a thin wall sleeve for the cup on the lathe. It fits the bearing correctly right? The Hot Rodder's Motto "Adapt,modify,make it work"
  7. lowsquire
    lowsquire
    from Austin, TX
    Turned up a match to the later ,thicker bearing cup, 6CE is the designation, have one on the way from Newcastle , will update this and show the fitment when it gets here, so this becomes a worthwile thread for those coming across this little hiccup in the future. thanks all for the help !
