1952-59 Ford Need some Ford Speedo Help.
Discussion in 'Off Topic Hot Rods & Customs' started by leadsledjim, Jul 13, 2012.
  1. leadsledjim
    leadsledjim
    from Iowa
    I am trying to get my new electronic Speedometer to work and the Pulse Generator will not work in my Stock 1953 Ford 3 Speed Trans.
    Sometimes works if I do not tighten it into the transmission.
    Afraid to leave it loose and have it fall off when driving.
    Anyone know what will make it work when tightened?
  2. old lady's mad
    old lady's mad
    id have to ask the technical dept where you bought it or the manufacture of it.
  3. leadsledjim
    leadsledjim
    from Iowa
    The pulse generator is from Ford.
    They told me to buy another Gear. That did not help.
    Has anyone had these same problems?
    Original Gear drives the cable fine.
    Same number of teeth on the new gear.
  4. old lady's mad
    old lady's mad
    well in that case, is it going into the trans to far? might try putting a washer under the clamp or whatever holds it down and see if that helps. if you match up the generator and the original cable end are they the same depth?
  5. leadsledjim
    leadsledjim
    from Iowa
    I Have altered the pulse generator and the gear so it looks like the original. Made the length the same and placed the gear in the same position as original. It appears that the small difference in size of the gears may be the problem.
