Need some glass install help
Discussion in 'The Hokey Ass Message Board' started by belair, May 5, 2013.
  1. belair
    belair
    I am putting gl*** in a 59 Apache. I have done front and rear before, and they are easy. BUT - how do you put gl*** in the doors? Does the front channel (the vertical one) have to be removed? What's the scoop on this? I have new channels and seal to go back in the door. Do they go in before or after the gl***? Any and all help is appreciated.
  2. scrubba
    scrubba
    Yes, take the division bar out . It makes for a much easier job. Once you have the gl*** attached to the window regulators , then you can feed the Division bar down through the top. It's not as hard as you're trying to make it out to be . scrubba
  3. the whole vent ***embly is a unit. the rear gl*** channel has a screw at the bottom that allows you to attach the gl*** channel to the regulator then slide the gl*** to the rear so you can get the vent ***embly back in
