Technical Need some help diagnosing unusual sound ,
Discussion in 'The Hokey Ass Message Board' started by jerrod1932, Oct 14, 2014.
  1. jerrod1932
    jerrod1932
    from calif
    Trying to help a friend out. he has a 1930 model a pickup truck. It makes kind of a howling grinding sound when you decelerate, especially when your in 3rd gear and are going 25 to 30 mph. doesnt seem to be coming directly from the transmission , or the engine, but we cant seem to pinpoint where its coming from, or what the problem is. Can anybody shed some light on possibilities?
    thanks in advance, david
  2. Ralphies54
    Ralphies54
    U Joints?
    Fender1325 likes this.
  3. Mike51Merc
    Mike51Merc
    Howling, grinding, growling are sounds that bad wheel bearings make.
  4. Blacktop VooDoo
    Blacktop VooDoo
  5. Fender1325
    Fender1325
    Rear end gears whining?
  6. Since you didn't state stock or otherwise should go off of a stock 1930 driveline ?
    Noise on deceleration is usually a pinion bearing.
    Put it up in the air and run it, that may help you track it down. At least you can have a shot at finding it.
