Hot Rods Need some help on this
Discussion in 'The Hokey Ass Message Board' started by telecaster guy, Jul 1, 2016.
  1. telecaster guy
    telecaster guy
    Here's what I have. 31 Model A PU. I have 56 F100 brakes on the front and a Maverick rear end with stock drum brakes. I have installed new brake shoes and drums, bled the brakes,no leaks,everything good inside the drums with no leaky wheel cylinders. The problem is, I have a hard pedal but the brakes won't pull up. I have all the shoes adjusted correctly. The master cylinder is new also ( I did bench bleed it) its a 67 mustang item for drum brakes. Could it be the MC is bad,even a new one? I ran the car up on 4 jackstands and went slowly in drive,stood on the brakes and the back wheels were still turning even though I'm holding pressure on the pedal. Any ideas?
  2. i have the sane setup on 3 cars and all work fine , so yours should too. my guess is maybe the shoes are not arced to the drums. pull the drums and see how much contact you are making
  3. Dan Timberlake
    Dan Timberlake
  4. dan griffin
    dan griffin
    It might be the levage on the arm.
    redlineracer42 likes this.
  5. telecaster guy
    telecaster guy
    Contact with the drums seems ok, arm leverage is the same as it was with the old MC.
  6. chiro
    chiro
    Are you certain you got the correct '67 Mustang all-drum M/C and not the disc/drum M/C? They did come both ways, you know.
    Andy
  7. tb33anda3rd
    tb33anda3rd
    how did you adjust them?
    i adjust drum brakes by tightening them till they are "locked", [can't turn the wheel by hand], then back off six clicks. if it still is hard to turn back of a few more. when done all the wheels should be backed off the same amount. of course you will have to repeat the procedure once the shoes break in.
    volvobrynk likes this.
  8. telecaster guy
    telecaster guy
    I got the drums MC, so the parts guy told me Do you have a part # for me to check? or how do I tell the difference?
  9. telecaster guy
    telecaster guy
    I did all that as you say.
  10. Did you put an adjustable portioning valve in for the rears?
  11. 325w
    325w
    have the drums been turned way out.
    shivasdad likes this.
  12. telecaster guy
    telecaster guy
    Brand new drums.
  13. telecaster guy
    telecaster guy
    No I haven't, I figured that was for discs on the front and drums on the rear
  14. Ok well I was going to tell you to adjust it full open if you did.
    If you have a stiff pedal, but no brake actuation I'd be looking for either an obstruction in the line that's blocking the fluid flow against the pressure on the master's piston
    or
    A mechanical hitch some place at the pedal or internal master.
  15. Dino 64
    Dino 64
    from Virginia
  16. Dino 64
    Dino 64
    from Virginia
    Sorry didn't mean to post it twice. Hope this helps. ECI was very helpful.
  17. telecaster guy
    telecaster guy
    I can have all wheels off the ground on jack stands,put the car in drive and push the brakes pedal as hard as I can and the back wheels still dont lock up, they stop but not locking up. I can give it some gas in drive and the back wheels turn slowly. Cant figure it out.
  18. tb33anda3rd
    tb33anda3rd
  19. HOTRODPRIMER
    HOTRODPRIMER
    I'm with Dan on this,your master cylinder push rod may be to short and not applying enough pressure. HRP
  20. telecaster guy
    telecaster guy
    Yep, the pushrod I got with the MC is actually a bit long to fit so I refitted the old one and the pedal does seem a bit low,looks like I may have to get an adjustable one. Did a search and an adjustable one costs a bunch like $65 !!
  21. telecaster guy
    telecaster guy
    I have a brand new MC for drum brakes for a 67 mustang on it, bench bled too….chinese **** maybe?
  22. indyjps
    indyjps
    Adjustable arm. Many folks modify the stock one, thread both ends for a sleeve and find the right length, then either weld or pin the sleeve, or make an arm the right length.
    Buying the adjustable takes the labor out of it.
    Either way, I think you need an adjustable to find the right length/setting. Then make a permanent solution
  23. telecaster guy
    telecaster guy
    Yep, I thought of that, thats what I will do, thanks.
  24. Super64belair
    Super64belair
    One thought that comes to mind is regarding the bore diameter of the master itself. If the new master you got is of a different bore diameter, it could be why you aren't getting enough multiplication applied to lock the brakes I had a master cylinder I changed on a gmc box van with a hydro boost setup that turned out was put in the wrong box from the manufacturer. The van had minimal brakes once installed. I ended up taking it back off and then found out that it wasn't the right one for the application. Another suggestion that I use for adjusting drum brakes is to pick up an infrared non contact thermometer to check the temperature of the drums while test driving. If you get the temp between each side within about 10 degrees, you will have braking you will be happy with. Just some thoughts.
    Sent from my SM-T530NU using Tapatalk
