Need some help on trunk lid 54 belair
Discussion in 'The Hokey Ass Message Board' started by dandimand, Oct 28, 2012.
  1. dandimand
    dandimand
    from vancouver
    What are these two holes for ? they have a black outline around them with two broken bolt heads . [​IMG]
  2. cheezwiz
    cheezwiz
    they were for the "locater" pin which bolted on. You should have a piece welded to the trunk jam in the corosponding spot for the receiver.
  3. dandimand
    dandimand
    from vancouver
    Ok I have that piece but because I replaced the rear trunk panel it doesnt exist anymore . Is it necessary to have this ? I know what you're talking about looks like a *** sort of I found it in the box of parts .
  4. CodeMonkey
    CodeMonkey
    from Moline IL
    Personally, I'd add it back on - it adds to the stability of trunk lid when closed, rather than just relying on the latch to hold everything in alignment. Might also prevent chasing a stray rattle or squeak...
  5. dandimand
    dandimand
    from vancouver
    Does anyone have a picture of what the receiver end looks like the part welded on the bottom ?
  6. 325w
    325w
    Look over at a tri 5 parts book. The parts look the same.
  7. CodeMonkey
    CodeMonkey
    from Moline IL
  8. fastcar1953
    fastcar1953
    here's mine.
  9. cheezwiz
    cheezwiz
    I cut them off of my car because I'm going to use a different latch. Not so sure that was wise.....anyway, I THINK I kept both pieces if you need them. Might take a minute to find them tho.........
  10. dandimand
    dandimand
    from vancouver
    I can see why they are needed now so will install thanks for the help guys .
  11. dandimand
    dandimand
    from vancouver
    If anyone has one of these cars with all the stainless on it and original and doesn't mind taking pics around car fairly close up it would be much appreciated and either post them or email them to me . I have a 54 belair 2dr hardtop . It's been a while since I took it all apart about 4 years and need a map or pics to figure out what I have as I have some duplicates etc... Plan is to fit it all first fix any damaged pieces then get car ready for body shop in feb .
  12. dandimand
    dandimand
    from vancouver
    Here is some pics of the build .
  13. CodeMonkey
    CodeMonkey
    from Moline IL
    Gonna be one nice ride when you're done - keep posting the pics!!
  14. dandimand
    dandimand
    from vancouver
    Thanks that helps with the chrome trim I've had the car for about 6 years had the frame and most of it done in 2009 then it sat due to other work in shop etc... .
    I see two little tangs sticking up on trunk area I ***ume these are for the rubber bumpers as I can see holes in my trunk lid around same area . If anyone has ever had the experience of removing the screws from trim that break on one of these cars its a real pain in the **** . I'm not sure what they used for metal back then but the hardness is ridiculous lol . I would like to find a manual for how to ***emble the window regs tracks etc.... if you guys know of one ?
  15. bryan6902
    bryan6902
    Nice work! Ever think about a full build thread? Maybe I've missed it?
  16. dandimand
    dandimand
    from vancouver
  17. dandimand
    dandimand
    from vancouver
    When I remove the frame I will finish off the bottom welds etc... then send out for powder coating . Man is this thing alot of work the frame was the easy part for sure
  18. dandimand
    dandimand
    from vancouver
    How do I post a full build thread ?
  19. arkiehotrods
    arkiehotrods
    Just start another thread ***led, "My '54 Bel-Air Build" and then start posting pictures and tell us what you've done!
  20. dandimand
    dandimand
    from vancouver
    I tried but the moderator said my car wasn't conventional enough oh well .
  21. dandimand
    dandimand
    from vancouver
    Here is a few more pics .
  22. That's some nice work. Looks like it will be a really cool car.
  23. paint2live
    paint2live
    Great looking ride! who makes that rear valance sheet metal piece that you have replaced under the decklid? Must be common rust area
  24. wizzard23
    wizzard23
    Love the shape of those louvers.
