need some help to i.d. chevy trans
Discussion in 'The Hokey Ass Message Board' started by 49 chevy, Aug 30, 2008.
  1. 49 chevy
    49 chevy
    purchased a 3 speed trans for bell. just curious what the trans might be. casting number is 3743368 - d149
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    How about a pic
  3. oldspert
    oldspert
    from Texas
    nice "X" blocks
  4. 49 chevy
    49 chevy
    This trans came from a 65 292 if that helps. What kinda horsepower can this handle
  5. 55 dude
    55 dude
    sounds lke a truck transmission to me. where are the pic's? what are you planning on doing with it. how long is it? does it have provisions for trans mount?
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    If it is a side/collum shift it would be a Saganaw full syncro 3 speed. You could run it behind a warm 350 if ya don't beat on it too hard.
  7. 49 chevy
    49 chevy
    Not really sure what i'll do with. Just wanted the bell housing, flywheel , clutch and pressure plate that a guy had for sale. Basically the trans was a bonus.
  8. 49 chevy
    49 chevy
  9. squirrel
    non-synchro 1st gear. Short tail. It'll handle a mild small block, but I wouldn't want to try to put too much power power thru it...
    (it is not a Saginaw, they used the old non-synchro Muncies thru 66)
  10. 49 chevy
    49 chevy
    SOME RESEARCH I FOUND SAID THAT THESE TRANS WERE USED IN CORVETTES AND MATED WITH A 327 THAT PRODUCED 250 H.P AND 350 FT LB OF TORQUE. i'M PUTTING A 283 IN MY 49 TRUCK. WAS PLANNING ON USING A 3 SPEED SAG. THAT I HAVE LAYING AROUND. BUT MAYBE I'LL USE THIS INSTEAD. WANNA KEEP THE STOCK REAR IN THE TRUCK FOR LOOKS. NOW THE GEAR RATIOS FOR THE SAG IS 3.11-1.84-1.00. THIS NEW ****** IS 2.58-1.48-1.00. WOULD THIS BE BETTER FOR HIGHWAY SPEEDS THAN THE SAG. OTHER INFO I GOT SAID WITH THE SAG. MAYBE I COULD GET 55-60 ON HIGHWAY. ANY THOUGHTS?
  11. Rich Rogers
    Rich Rogers
    1.00 is still 1.00 .The new one has a taller 1st and 2nd but 3rd will be the same
  12. squirrel
    Yup, high gear is the same with both transmissions.
    With the saginaw you'll be able to downshift into first without having to come to a full stop (or double clutch) like you would with the non-synchro trans.
    Saginaw should be longer too. Do you have a driveshaft already?
  13. 49 chevy
    49 chevy
    YEAH THE THE SAGINAW IS LONGER. ABOUT 3-4 INCHES FROM A SIDE BY SIDE COMPARISON. THERES A DRIVE SHAFT IN THE TRUCK. NOT SURE YET IF IT WILL WORK. I KNOW IT WILL NEED SHORTENED IF USING THE SAGINAW. BUT NOT SURE IF IT WILL BE USABLE. IN THESE TRUCKS THE DRIVE SHAFT AND REAR IS A CLOSED UNIT. I THINK I SHOULD JUST CHANGE REARS AND BE DONE WITH IT. HERE SOME PICS OF MY PROJECT. A FARMER RAN THIS TRUCK TILL 1993. THEN PUT OUT TO PASTURE TO DIE. I GOT ABOUT A 1 1/2 YEARS AGO. GOING TO TRY TO RESERECT.
  14. squirrel
    If the rearend is the closed driveline type, then you'll need a different rear and driveshaft to work with either of those transmissions.
  15. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep Squirrel you right -me wrong on years used. Don't know what I was thinking er THINKING that was the prob.
    49 Chevy :Use the Saganaw a lot tougher than the early box. Years ago had a 300 HP 327 in a 59 Vette and tied them things in knots, finally gave up and stuck a Munice in it. Matter of fact that that basic box dates back to 49 and my 261 Chev 6 blew up a bunch of them also.
  16. 49 chevy
    49 chevy
    kinda figured i had to change rears. i gotta ford 9 in laying around that i might throw under. thank for the info
  17. 55 dude
    55 dude
    if tou want to keep it 6-lug a 55-59 rear bolts in. checkout www.stovebolt.com all the info for your upgrades are there. killer truck site.
