need some help w brakes
Discussion in 'The Hokey Ass Message Board' started by dantheman311, Jan 27, 2012.
  1. dantheman311
    dantheman311
    from carson ca
    i got a couple of questions
    i have a pontiac bonneville 1967
    all drum brakes and was wondering if anyone know how hard it is to change to disc thanks
  2. 55chieftain
    55chieftain
    Not too hard, the old way involved finding a doner full size 69-70 and do the swap with the knuckle ***embly. But those rotors are like hens teeth finding new if they need replaced. Full size 67 was available with disc but the 4 piston calipers are a pain and not worth the h***le unless for a restorer.
    Now you can keep the drum spindle and get some disc brackets from Scarebird for the conversion and go with a dual reservoir master.
    You might catch some slack from some guys here since this is a 64 and older forum. Also check over on Performance Years on their forums as well.
  3. metalix_421
    metalix_421
    with that said ^^^^^ I would say find someone that sells a kit for your car and install. may have to do a little bit of welding but other then that pretty strait forward.
  4. dantheman311
    dantheman311
    from carson ca
    thanx alot really appricate it i believe i already have a duel reservoir so im going to look for those brackets ...
    i been looking for an older pontiac 58 bonneville would be nice
  5. yes, you have a dual master, but you will need to change it to one for a disc/drum car (a slightly newer one will work) and round up a proportioning valve which goes in where the junction block on the frame is now. For your application, a factory one for a GM fullsize car will work.
  6. dantheman311
    dantheman311
    from carson ca
    do you have any advice on what year the master cylinder should be
  7. swe64
    swe64
    MPBRAKES.COM have kits.
    and if you want 8-lugs dummies disc brake ROUSH.COM HAVE it you have to buy 15 inch rims for clearence
    i got my 15 inch rims from BOP.I WILL SEND PICTURE.still have good drums but i think i will swap to disc brakes later on
    kensweden
  8. The year is not as important as the brake setup on the donor car.
    That being said, anything 70's and up should be safe (caveat emptor)!
    Sent from my iPhone using TJJ!!!
  9. gimpyshotrods
    gimpyshotrods
