Technical Need some help with Brakes
Discussion in 'Traditional Hot Rods' started by cannondale-rob, Apr 7, 2015.
  1. cannondale-rob
    cannondale-rob
    from Eagle, Id
    OK, I need some helps with Brakes on my 36 5-W. I am converting my wide-5's to 16" steelies. I am all set with the Front. I have a pair of 40 rear drums that the hubs are good, but the drums are shot. I have a swedge cutter, so I am going to separate the hubs from the drums. So here is the question. If I buy replacement drums, do they have to be swedged back to the original hub, or can I just run the drum over the hub, with the wheel and lug nuts holding the drum in place? It is very confusing what the manufactures of these drums say. I am having no luck at all locating useable rear drums, so my only choice is to look at using these new drum options. Any guidance that could be offered is most appreciated!
  2. I also will be swapping in some new drums at some point so how about a bump to the top!
  3. 19Fordy
    19Fordy
    I bought the MT Brake Products Bendix brake drum kit and their replacement drums. They slide over the studs and are held in place by the lug nuts. They also could be used and held in place using lug nuts and the original hubs but I chose to buy new replacement hubs which come with the studs installed.
  4. seb fontana
    seb fontana
    from ct
    As long as the drum center hole and the hub locating od are a close fit, the studs will do fine..49' up has no issues;)
  5. fatkoop
    fatkoop
    I replaced the drums without swedging on my '40 about 2 years ago. Probably have at least 10,000 miles on them by now, no problems.
  6. RICH B
    RICH B
    Once you cut the swedge there is nothing left holding the original studs in place. There are press-in serrated studs marketed for use with the cast iron repop drums. The drum is then retained by the wheel and lug nuts.
