Need "Some" help with my 51 Chevy
Discussion in 'The Hokey Ass Message Board' started by cavistyle, Mar 10, 2010.
  1. cavistyle
    cavistyle
    from baltimore
    I have a 1951 chevy 2dr that I am attempting to rebuild. I need some help tho... Here are some questions I have...
    What are the best after market leaf springs to use. I am running a 81 Trans am rear end.?
    How do i make sure the rear end is centered correctly?
  2. Rickybop
    Rickybop
    I don't know who makes the best kits, but I do know that they design them so that the rear axle is centered. That is, centered in the wheel-wells. As far as side to side, the spring-pads have to be welded in position to match the springs. I believe there is an axle or two that match right up...somebody here will know. If you have to reposition the spring-pads, don't forget to match the pinion-angle to the out-put shaft of the trans.
  3. redhawk74
    redhawk74
    i just bought a 51 chevy, and everything that i have read thus far says a rear end out of a 68-72 nova would work, and i guess the pads line up fairly decent, with the execption of the differenc in width between the stock leaf springs, and the pad.
  4. cavistyle
    cavistyle
    from baltimore
    Yeah, The camaro/trans am rear also work width wise. I am looking for diffretn leafs tho. The stock f body leafs make the car sit way too high. Since I am going to buy new leafs I was wondering if there was another set that would work better for me
  5. 51hrdtp
    51hrdtp
    Walton makes springs for after market rear ends. I have a 51 hrdtp with a 1983 capriece rear end . New leafs with all the hardware and new mounts/shocks for about 500 dollars. They are the chevy 49-54 rear leaf spring people.
  6. t-buckethead
    t-buckethead
    from texas
    go to 50 chevy.com
