Need some idears!
Discussion in 'The Hokey Ass Message Board' started by erock805, Jan 10, 2009.
  1. erock805
    erock805
    Cant remember, back fire through the carb under quick acceleration means fat or lean?
    Could this be a timming issue? I am running 10 initial and 30 total all in by 3400 rpm. small block chevy. edelbrock carb, msd ignition.
    runs smooth everywhere but under quick acceleration...dangit!
  2. Don Moyer
    Don Moyer
    Not a Chevy guy, but I don't think 30 is enough total, so I would bump it to 36 and see what happens....
  3. chopper99
    chopper99
    Check your intake manifold for a vacuum leak, had exactly the same problem once and that was the cause.
  4. erock805
    erock805
    Thanks guys...Keep em coming!!!
    wouldnt total timming not even come off into play. The issue is going from idle to wot, quickly. Total timmin would be power loss up top. just my thoughts, but I do think your right...36 sounds better as memory serves...
  5. power58
    power58
    Paul Senior at Orange County Choppers has lots of Idears. Let us know what you find out when you get it goin.
  6. zzford
    zzford
    Sounds lean to me.
  7. budd
    budd
    i would look at the accelerator pump and power valve.
  8. coupster
    coupster
    from Oscoda Mi
    any more details? New engine? Old engine? Miles on engine?
  9. Mike Miller
    Mike Miller
    Soundl like a lean condition, is there a little stumble when you transithion from an idle? remember more advance needs more fuel so if you raise your advance you will lean out your top end. Are you running a Holly twice pumper? I traced a problem like yours to the accellerator link, no clearance, the clearance between the screw and the pump arm should be .010 elsewise it sits there and vibrates pumping the accellerator half dry so you don't get a full squirt when you mash the throttle. my $.02
  10. JC Sparks
    JC Sparks
    from Ohio
    I agree with looking at the accelerator pump.
  11. One backfire(tuning) or several(possible flat exhaust cam lobe)?
    You ask if it's timing. Bump it up and see if it likes it would be an easy answer. But, if I had to guess, weak accelerator pump shot
  12. erock805
    erock805
    took some intial timming out of it. messed with the accelator pump. fattened up a bit....I think Im close. Need more total timing I think though. When I hook up the vac*** advance the timing shoots way up, idle picks up too.
    Wish I knew wtf I was doin...anyway
    Took it for a spin, ran the piss out of it...
    now I got cooolant everywere....more issues!
    Wouldnt know about Paul SR.
  13. fab32
    fab32
    Stumbling or backfire on rapid acceleration is sometimes a sign of accelerator pump malfunction. Check to see if you get a strong discharge out of the pump squirters when you open the throttle rapidly.
    Frank
  14. Sounds like you're trying more than one thing at a time. You'll not know which helped, or if the 2 things counteract eachother. The vacuum advance should be hooked to "ported" vacuum. A source that supplies vacuum at the crack of the throttle, NOT at idle. It's NOT more total, but initial timing that'll affect your off-idle response. Take it to a shop:eek:
  15. K13
    K13
    HAHAHA I think he was making a comment on your addition of the r to the word ideas. Something Paul senior does as well.:D
  16. power58
    power58
    I watch American Chopper all the time. Paul Senior Says he has Idears all the time. I think its a Cool Word. Thought maybe you were speaking Paul Senior. Good Luck with the Car, sounds like your making headway.
  17. Psychobilly351w
    Psychobilly351w
    from 732- NJ
    could be a bad power valve or accelorator pump. had a holly 442 that backfired like a sone of a ***** on accelorationon a 390, it was the accel. pump.
  18. Psychobilly351w
    Psychobilly351w
    from 732- NJ
    **4412
  19. erock805
    erock805
    Threw a belt when I was drivin the hell out of it....that made my coolant issues. I will swap the vac*** port, Hell I dont even know if an edelbrock carb has a power valve...lol
    Its just quick initial, right from dead idle. When I was driving it I didnt even have it pop once. Anyway, The carb has been sitting, (but looks new and unused) so I could have some issues with it.
    After I get another belt I will keep messin with it...thanks for all the suggestions...
