Projects Need some opinions on some gauge panels I made up
Discussion in 'The Hokey Ass Message Board' started by twenty8tudor, Dec 12, 2015.
  1. loudbang
    Like the others number 2 for the all in one spot reason.
  2. NashRodMan
    NashRodMan
    You stated..." I could do a step by step on how I made it."
    Please do!!! Lol. Nice work!
    Paul
    Hnstray likes this.
  3. dan31
    dan31
    I kinda like #3. To me #2 looks a little busy, taking away from the centered stock gauges.
  4. brady1929
    brady1929
  5. NotSoNewKid
    NotSoNewKid
    I think I like 2 best as well. This is something I'm going to have to figure out too.
  6. 56 Dodge Pickup
    56 Dodge Pickup
    You could go with this option I filled the dash pod holes and split the dash pod fabricated a new center section to insert the gauges on my 37 Plymouth.
  7. i.rant
    i.rant
    I'm all in on the column panel, number 2 is a close 2nd option. :)
  8. Kevin Lee
    Kevin Lee
    Super Moderator
    Huh... I liked the first one. Super simple and didn't strike me as a parts store thing at all.
    To me the second one was so "designed" it's just screaming "Hey guys! But look at all of these extra gauges down here!" And my eye isn't really sure what's more important – the main gauges on the dash, or the extra gauges below. But maybe that changes when the panel is painted?
    All of that said, looks like great work no matter what shape you end up using. Thanks for taking the time to post the pics.
  9. Petejoe
    Petejoe
    from Zoar, Ohio
    Two or HRP's #4.
  10. xpletiv
    xpletiv
    from chiburbs
    #2 has the same design shape as the original so it looks like it belongs, plus it looks like you really paid attention to what you were doing when you made it. :)
    Now, if you could fab a cardboard one like Charlie Stephens posted, but with better style.
  11. David Gersic
    David Gersic
    from DeKalb, IL
    Do the cardboard one the same way you did #2 and you'll have a winner.
  12. twenty8tudor
    twenty8tudor
    from Ohio
    Ok here we go....
    First time posting a how to... Let see how this goes
    Put tape on the tank to find the center of the column
    Held the gauge up with the clamp on the back to make sure I had just enough room for it in the side
    Marked the center of it on the tape and measured down to see how far I needed to be off the tank.. Made the mistake on one of the others I was trying and after setting it in I seen that if I installed it I would not be able to get the gauge in or out due to the curve of the tank..
    Transferred those marks on the tank onto cardboard and made the mark for the column..
    Marked the center of the gauges down and also measured the edges of the drop so the arch would cover it.. Used a comp*** to mark the holes inside and outside to make sure it looked right..
    Used 2" holesaw for the gauge holes and 1.5" for the column.
    Cut a slit in the column hole so I could slid it over and set the gauges in
    Cut the template straight down the middle so I could make sure both sides were exactly the same.. Used a comp*** again to mark out 1/4" farther so I would have a track for the roller to run in.... Also left extra at the top so I have some extra to cut off to make it fit the tank
    Went over the marks with a sharpie to see better
    Only vise I have solidly mounted is on the mill... Putting a harbor freight bead roller in a Bridgeport is about the same as putting vending machine ring on a supermodel....
    Stepped up the pressure over a couple p***es
    Ruff trim on the portable bandsaw.
    One nice thing about a cheap roller and putting some pressure on it is it will leave a scribe mark which I sanded the edges till it was gone
    After sanding and used the carload to mark the holes again..
    Used same hole saws to cut the holes
    Ground the top down to fit the tank and enough to let the drop clamp the column. Then Set the gauges in
    Thinking of a starter ****on in the middle to fill the extra void..
    Thoughts on this panel compared to the others...???
    BradinNC, Tim, David Gersic and 3 others like this.
  13. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    That's the one. Nice work.
    twenty8tudor likes this.
  14. '52 F-3
    '52 F-3
    from Central PA
    thanks a lot for all the pics/posting this.... it's something I've been pondering myself. I wanna use my 29 fuel gauge and update/add other gauges. I like what you've done also. I'm considering adding "wings" or something to the original panel but the depth is an issue.
  15. Jalopy Joker
    Jalopy Joker
    last one , with influence by HRP, looks good. since you lost a place for a voltmeter, how about putting a "idiot light" in center?
  16. xpletiv
    xpletiv
    from chiburbs
    Since I don't know what goes where ("you eedeeot!"), what are you filling the 3 (or 2?) holes in the original with?
  17. twenty8tudor
    twenty8tudor
    from Ohio
    The hole in the middle I will put the original instrument light back in.. And the key back in the left side.. Not sure on the right where the amp gauge went
  18. Since there is not a lot of room behind the panel an original amp gauge might be a good idea.
    Charlie Stephens
  19. twenty8tudor
    twenty8tudor
    from Ohio
    Problem is I have a high output generator/alternator in case I run an electric fan.. The ones from macs only go to 30 amps..
  20. 40ragtopdown
    40ragtopdown
    #4 is awesome going to try that thanks for posting
  21. Canuck
    Canuck
    twenty8, a band welded around the edge and metal finished gives a nice finished look and hides the side view of the gauge can.
    I masked off the raised bead and sand-blasted the flat area before painting, to give it a little texture,
    Canuck
  22. 40ragtopdown
    40ragtopdown
    Canuck your right that band really gives it the finishing touch.
  23. twenty8tudor
    twenty8tudor
    from Ohio
    That's the next step is to add a band around it.. And hope I don't mess it up haha
  24. stronga
    stronga
    I vote for #2
  25. Canuck
    Canuck
    Like the looks of #2, just have to make the bead follow the shape of the gauges on the ends better.
    The best is the column mounted version, again just have to make the bead follow the shape of the gauges on the ends better. On the initial cardboard template they were good, just ended up squarer somehow. Also if it could be done following closer to the steering column and following the column's diameter I think it could look better.
    With a band. :cool:
    Canuck
  26. Jalopy Joker
    Jalopy Joker
    Canuck is on to something - but, not only that - tighten amount of metal around gauges and have the flow go part way around the upper part of gauges - instead of a full flat edge like now. end up with a shorter flat mounting surface - this would help the extra gauges set up compliment the original dash center form more - (0 0)
  27. twenty8tudor
    twenty8tudor
    from Ohio
    The problem I run into with trying to have the bead go around the top is I then have to move the gauges out to clear the column drop.. Due to it being wider as it goes down..
    I have two more holes to drill and then tap in the could but I think it will work till I can drive it for a bit..
    I added a band as suggested to hide the back of the gauges and strengthen it since it's only 22gauge..
    Outside of weld
    Inside of weld... I don't know what I did before I had a tig....
    Grind and sand the weld down
    And I think I'm gonna call it done enough..
    harpo1313 likes this.
  28. The 39 guy
    The 39 guy
    Great project with a excellent outcome! Thanks for posting your process!
  29. David Gersic
    David Gersic
    from DeKalb, IL
    I like it. Nice.
  30. Jalopy Joker
    Jalopy Joker
    yep, at some time gotta stop. can keep modifying some stuff and not make any real progress. but, when you watch Chip Foose on his TV show there are some elements that worth going above and beyond for.
