Technical need source for 1940 Plymouth trim clips
Discussion in 'The Hokey Ass Message Board' started by willys36, Nov 26, 2023.
  1. willys36
    willys36
    I need about 150 of these little stainless trim clips for a 1940 Plymouth. I ***ume Auveco carries them but I can't find a listing on their site. Anyone know a source or part number.
    Tow Truck Tom likes this.
  2. rockable
    rockable
  3. willys36
    willys36
  4. willys36
    willys36
    Thanx. Your link got me to a different place in Auveco. I think this is what I need.
    1959-CLP
    Write a Review
    Your Price: $1.50
    Part Number: 1959-CLP
    Description: Moulding Fasteners *Call for Availability before Ordering. Many sizes and types of these clips are available. Please send pictures or samples. Hood Side Moulding Fastener Chrysler 1940
    bobss396, Tow Truck Tom and rockable like this.
  5. rockable
    rockable
    I think I spent 3 days putting my grill together. lots of strips and I had to drill over 80 holes.....after the car had been painted.
    Tow Truck Tom and willys36 like this.
  6. willys36
    willys36
    My grille, body, and stainless trim are in pristine condition. I think if I can find the proper clips it will be a simple plug and play operation. I know, I know, it's a pipe dream but I can hope can't I!
    SS327, vtx1800 and Tow Truck Tom like this.
  7. bobss396
    bobss396
    Their catalog was around 900 pages at one point, but chances are good they will have what you need. One I found for a friend, he had to buy through a distributor, they at the time, did not sell retail.
  8. Skrambler
    Skrambler
    My two cents worth. IF and only IF they claim to have those clips in stock, "I" would ask for a single clip BEFORE purchasing a hundred. You will find that there are many arrowhead type MoPar clips that look similar to your example but they will not fit either the molding or be too long or too short to hold the bar to the grill panel...
    caprockfabshop likes this.
  9. willys36
    willys36
    Yep. I had one of their catalogs back in the day. Now that cats are on-line no need for the hard copy but they make the search engines too complicated to find what you are looking for most times.
    bobss396 and partssaloon like this.
  10. RodStRace
    RodStRace
    This is one of the rabbit holes I have not gone down on mine. Would like to hear which you end up using with part numbers!
    I will tell you that the 6 small strips on top are narrower and use smaller clips than the grille parts, and the hood and body strips are a bit wider than the grille. The center strip uses a clip with stud and nut.
    This seller has a number of different clips with kind of generic part #s, like 1956 and 1953. These might be helpful if you can find the replacement catalog. Having even OE numbers won't help if the sellers are using replacement part numbers.
    It appears that the part of the clip that is inside the trim has various curves to fit the trim part.
    https://www.ebay.com/usr/soaparts?_trksid=p4429486.m3561.l2559
    bobss396 likes this.
  11. willys36
    willys36
    Good start; they asked me to send them a sample so should be able to get exactly what I need. I think the lower grille bars and body beltline trim both use the same clip. The body trim flanges are close together to accommodate the same clip. Will report what they come up with.
    RodStRace likes this.
  12. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Might try this guy.
    https://www.oldmoparts.com/
    I’ve never done business with him but you might check it out and find what you are looking for.
  13. 28rpu
    28rpu
    I picked up the correct different sized clips I needed for my '40 Plymouth trim from Clipsrus on ebay. It's been 11-12 years ago so don't know what they have now.
    willys36, RodStRace and bobss396 like this.
  14. bobss396
    bobss396
    This was for an OT clip for one of his customer cars. By sheer luck I came across it... online. Like finding the needle in a haystack.
  15. bobss396
    bobss396
    One thing you need to be aware of, some places like Macs and Carpenter (on Fords) will list ONE clip to do the long fender piece on my Ford. It actually takes 3 or 4 different ones. I had the factory trim manual that showed them correctly. Restoration Specialties had them all.
  16. RodStRace
    RodStRace
    28rpu, that delivery is beautiful!
    28rpu likes this.
  17. RodStRace
    RodStRace
    Okay, it would be nice to have something like this for the 40.
  18. RodStRace
    RodStRace
  19. RodStRace
    RodStRace
    The same seller, Faxon literature has this, which covers the whole car.
    https://www.ebay.com/itm/1627606039...ymouth&hash=item25e549b94a:g:6l8AAOxyA4ZRS2Xf
    "This reproduction of the Chrysler publication is your ultimate resource for finding original automotive hardware. Make your car original down to the last nut & bolt. You will find standard hardware parts such as bolts, fittings, nuts, pins, screws, fasteners, springs, and washers. See drawings of original parts along with original part numbers, part names, diameter, thread dimesions, length, material, and finish. Includes indexes by part names and by part number. Buy now for this hard-to-find reference."
    Sounds like the best deal at 24 bucks, BUT it does not list aftermarket part number reference, so that would be another concern trying to track down the right clips.
  20. RodStRace
    RodStRace
  21. willys36
    willys36
    That's them I reckon. This topic brings up a peeve of mine. Why make 9,134,953,850 different clips to do exactly the same job on every car made? Why not make the 3 or 4 clip designs that would cover every application?
    Why make just as many sparkplug designs? All they do is spark. Make the 3 or 4 styles that would cover every engine ever built.
    Why make thousands of tie rod end designs? Make the 3 or 4 sizes that would fit every vehicle ever made.
    There. I'll get off my soap box and go back to drooling in my corner.
  22. RodStRace
    RodStRace
    Agreed. Jaguar used the same front wheel bearings from something like 1937 to the 80s. Guess what, a car around 3-4000 pounds has roughly the same loads, even through most brake and tire changes.
    Same with those plastic clips, 3-4 sizes and 2-3 depths should cover 99% of use, but NOOOO!
    O-rings come in standard sizes, don't make something special!
    How many different coolants are needed?
    And one of my favorites, even high school dropouts understand drain plug goes at lowest point, make clearance for the fluid to drain without other things in the way! But engineers can't figure this out?
  23. Skrambler
    Skrambler
    Willys36
    I may, and mean MAY have found the clips you are looking for. Let me know if you are still in need of them, or if you worked something out.
    I was not with my phone when I found these so I will have to return to them to photograph them if you are still interested.
  24. willys36
    willys36
    Definitely interested.
  25. Maybe make your own.........but making a 150 or so would kinda ****.
