need special rear brake tee
Discussion in 'The Hokey Ass Message Board' started by nmpontiac, Oct 17, 2013.
  1. nmpontiac
    nmpontiac
    from Taos, NM
    I need a brake tee with a 7/16-20 female inverted flare in and two 7/16-24 female inverted flare out to repair a customers early chevy pickup. Didn't look like Dorman had one though my Dorman source wasn't all that enthused to help. Like the picture only with 7/16-24 on the two "out" ports instead of the 3/8 shown.
  2. Bert Kollar
    Bert Kollar
    Speedway 910-31849 good book to use for reference
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Try your local Ace Hardware my tee stripped and found just what I needed there,also got all the fittings I needed to do the dual master cyl swap.
  4. 325w
    325w
    Try the local hose maker.
  5. Edelman, Weatherhead and Everco do not list that combo in my book.
  6. 01spirit750
    01spirit750
    from Ohio
    Give these guys a call and see if they have it. If they do I will pick it up and ship to you. They are about 1/2 mile from my office.
    http://www.rbisj.com/
    Royal Br***
    1700 Martin Avenue
    Santa Clara, CA 95050
    (408) 727-4327
  7. nmpontiac
    nmpontiac
    from Taos, NM
    Thanks to everyone for the help - the problem was that the customer bought some pre-formed lines from LMC and they had the 7/16-24 nuts on the tee end- it was 3/16 line and I had just enough straight tubing left on the end after I cut the flare off with a razor saw to redo the flare with the 3/8-24 nut and re-use the tee I had. Ridgid double flare tool to the rescue (again)
