I just got a 36 ford front axle, but it still has mechanical brakes on it. what I would like to know is what later model spindles and hyd. brakes will fit my 36 axle. I used the search function but had no luck, maybe I didn't put in the right keywords or something, so if someone could point me in the right direction I would greatly appreciate it. Thanks
With kingpins to match the spindles,all ford car spindles up to 48 and some light truck spindles will fit the axle.Easiest brake swap is use the brakes that go with the spindles.
