Technical Need TH350 ID help
Discussion in 'The Hokey Ass Message Board' started by Humboldt Cat, Dec 17, 2017.
  1. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Scored a TH350 to make my '62 Stude wagon a basic runner (no trans for its stock mill, which I'm saving for the '28 Stude proj). Very interested in decoding it to know what, exactly it came out of. The Interwebs looking gl*** has helped only so much...
    With Cx stamp, I know it's pre-Aug 1968, the stamp on side o pan (JD13D) at least tells 4/13/69, tho don't know the "J" or the following 5JC figure.
    Plate behind torque verter features 8K 6260233
    A # at tailshaft: 28L164438 and a 78 in a circle. Thanks for any help.[​IMG][​IMG][​IMG]
    Sent from my LG-US996 using The H.A.M.B. mobile app
  2. mohead1
    mohead1
    Pan, tailshaft, and oump behind converter dont mean much.
    ..should be a plate attached w numbers/letters to ID init
    Sent from my SM-G900V using Tapatalk
  3. squirrel
    78 means it's a 1978 casting date.
    Is the ac***ulator plug stamped steel, or cast aluminum? they changed to steel around 1977ish, I recall.
    (the TH400 has a tag with the numbers, the 350 does not)
  4. squirrel
    also in your pic that has the shift lever, there's a little casting circle with a hex sticking out of it, clean that off, it should have the last two digits of the years cast into it, as well
  5. squirrel
    Also, they were introduced in 1969 model cars, so you wont' find one from before August 1968.
  6. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  7. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Ok; there was a link I found along the way saying "C" signified Cleveland plant, the "x" meaning before that date. Anyway..
  8. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Likewise with the trans pan # decode info. Dang weekend Interwebs.
  9. squirrel
    I think this is the partial VIN:
    28L164438
    which translates as
    2=pontiac
    8=19x8 model year
    L=Los Angeles vehicle ***embly plant
    It's a stamped number, right?
  10. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  11. squirrel
  12. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Yes, a stamped number. Where would the hex-stamp be? On shift lever/driver side?
  13. squirrel
    the hex thing, that's circled in this picture:
    but I'm pretty darn sure it's out of a 1978 Firebird.
  14. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Ohh ok. What a trip :) will keep diggin when back from chores. Thanks for the help! Maybe the pan was borrowed from a different trans along the way. Or m***-produced?
  15. squirrel
    If the pan has a factory drain plug, it could be a very early pan.
  16. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  17. squirrel
    you see that 78 pop up in a lot of places on this transmission, eh?
  18. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    There, and encircled in a stamp on tailshaft. Pan doesn't have a drain plug.
  19. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  20. squirrel
    I think you've identified it as far as you can... CFD is the foundry name, I think
  21. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  22. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    [​IMG] Am up at the shop where the motor 'from' is... Scrubbin off a similar if not same 28L64438 number... Upper # may mean from Flint factory on April 9 and whatever CEM means...
  23. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
  24. squirrel
    305 engine, numbers matching!
  25. Bob Burgh
    Bob Burgh
    from Indiana
    Resurrecting the thread for some help Identifying this ****er. It is a TH350 with the BOP Speedo Sleeve (37 tooth, I think)
    VIN Stamp just above Pan is 35R101873
    I have zero history but guessing it is out of the 70's or 80's based on other factors
  26. Atwater Mike
    Atwater Mike
    From the HAMB annals... Again, the printed word.
