Need to narrow a ford 9" - Help??
Discussion in 'The Hokey Ass Message Board' started by maddog, Mar 25, 2007.
  1. maddog
    maddog
    from So Cal
    Need to narrow a ford 9" and have never done it before.
    I will listen to anything you guys want to tell me about doing it.
    Do I buy shorter axles or shorten them too?
    Thanks
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    You will need to make a jig to keep the axle centered.
    I made mine from a piece of 1 1/4" bar stock about 5' long. Then you need to make a pair of circles that have the carrier bearing OD. and the 1 1/4" ID. For the ends I made two different sizes for the Ford bearing sizes. Two circles with 1 1/4" hole in center. OD of the outer axle bearing and a flat plate welded to it so you can C-clamp the housing flange in place on the circles.
    Cut housing. Insert steel shaft thru the housing/centered carrier discs. Hang the cut to length axle housing ends on clamp to the outer circles. Make sure the steel bar moves without bind and tack weld the tubes in several places around. Checking for rotational bind. When everything is right, weld the tube up in 1" increments varying positions so not to warp housing.
    Used this fixture for more than thirty housings. When I started out I did splining too, with a Bridgeport and dividing wheel, but found it cheaper to send to the boys in Indiana.
  3. maddog
    maddog
    from So Cal
    Excelent. I followed you every step of the way.
    Any Idea what it costs to have it done?
    I dont have plans to do more than one right now and would like to compair the cost of both, doing it myself and sending it out.
    What boys in Indiana?
    Thanks much.
  4. 2manybillz
    2manybillz
    Moser charges $110.
  5. maddog
    maddog
    from So Cal
    Thanks all, just what I needed to know.
  6. Weld all your brackets on the housing before putting on the ends.
  7. maddog
    maddog
    from So Cal
  8. k55f5r
    k55f5r
    from SoCal
    Anyone know of a business that narrows 9" fords in the Inland Empire SoCal?
  9. onlychevrolets
    onlychevrolets
    SoCal speed shop can do it...or have it done
  10. k55f5r
    k55f5r
    from SoCal
    Money is an object. I can barely afford a sticker from SoCal Speed.
  11. HotRodMicky
    HotRodMicky
  12. choppintops
    choppintops
    If money is an issue, although Currie is top notch, cheap they aren't.
  13. oj
    oj
    To give you an idea of narrowing costs, i charge $350 to cut, weld new bearing houses and brackets (shock/ladder bar etcetc) hot tank. This is done with commercial jig and procedure that bobcrman & wfo man described. It isn't cheap to get it done. but it has to be done right the first time or it will get really expensive.
  14. choppintops
    choppintops
    :eek: I need to raise my prices. You are getting $350 for housings, no resplining axles? :eek:
  15. silent rick
    silent rick
    i had 2 housings narrowed and another small welding job done for $100. it was one of those deals where i tried tipping the guy an extra 40 bucks but couldn't get him to take it. he told me to call moser with some measurements he made off the housings and they would make the axles for me.
