Looking for some help - need a wiring diagram for a '67 Chrysler 300 V8 440 7.2L K Code 4 bbl. Any help appreciated. Thanks
You probably already know this, but on 60's Mopars the power for the car runs through the firewall into the dash, through the amp meter and back through the firewall out to the engine. The connector on the firewall is a real common trouble spot. It's worth pulling and inspecting the connectors from the engine bay side... Here's a pic of a 66 300 I had. Smooth riding car, the Wifey still misses it.
Hit eBay, I have some Chrysler wiring diagram books a little newer than that and near as I can tell I will hardly be able to give them away. So they should be cheap to buy.
The 68 I had years ago had issues with the firewall connector,someone did a crappy bypass which I had to repair. Run another wire from the back of the alternator to the battery or starter relay which helps greatly.
