Technical Needed drake alum. Dash insert mods
Discussion in 'Traditional Hot Rods' started by lowbolt1, Apr 12, 2020.
  1. Pics
    0 vote(s)
    0.0%
  2. Parts
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. lowbolt1
    lowbolt1
    from usa
    Need drake dash insert help
  2. sliceddeuce
    sliceddeuce
  3. lowbolt1
    lowbolt1
    from usa
    It's made for vdo size gauges.
    But they are very high cost.
    Would like to try n fit more affordable smaller size sw or other brand. Into this dash panel.
  4. sliceddeuce
    sliceddeuce
    So,......Turn a set of collars on a lathe.
  5. lowbolt1
    lowbolt1
    from usa
    No collars the vdo gauges are smaller dia.
    And mount in from the back and register into pockets, and retain with a special plate set up,
    The pocket needs to be carefully milled to fit bigger gauges carefully and rethinking the mounting llate.sooo
  6. sliceddeuce
    sliceddeuce
    You are making no sense at all. Take your gaggle of mis-matched parts to a machinist. Happy Easter.
    VANDENPLAS likes this.
  7. alchemy
    alchemy
    Yep, either take it to a machinist or use a die grinder and some sharp bits, and finish up with a sanding roll.
  8. I used one of Drake's alum dash panel in my 40 Ford. It called for VDO which I do not like. SW Wings
    would not back mount due to larger bezel but the vintage style Auto meter gauges back mounted just perfect.
    It gave me the look I wanted. They have vintage style needles & face comes in black or white. The bezel is small and rounded and fit into the panel like the VDO . Check them out . Jerry Drye from NC
  9. sloppy jalopies
    sloppy jalopies
  10. phat rat
    phat rat
    I didn't have any trouble using some Auto Meter gauges in Drakes 40 insert
  11. fordflambe
    fordflambe
    I just learned something, thanks for letting me know! I didn't have a clue that i was wealthy. I just used VDO without even knowing my socioeconomic status.
    kidcampbell71 likes this.
  12. lowbolt1
    lowbolt1
    from usa
    Sorry for any earlier mistakes under standin, and thank all who peplyed, yes I will follow up on the auto meter vintage line. See how that all fits together.
  13. catdad49
    catdad49
    Look at my avatar pic. Are these the gauges?
  14. lowbolt1
    lowbolt1
    from usa
    Could be, I cant tell from front view, need diameters,
    and a good close up side view of the bezel profile
    Thanks
  15. catdad49
    catdad49
    This is installed, look up Autometer #1601.
  16. I believe the one I use were called Autometer Old -Tyme Black. Look in Speedway catalog, they
    have a pic of Old-Time white & Antique Beige. Did not see the Black ones that I have. They
    look similar to ones catdad49 has on his avatar. Jerry from N C
