needed help and no one was around
Discussion in 'The Hokey Ass Message Board' started by gasmanm01, Jan 19, 2013.
  1. gasmanm01
    gasmanm01
    i love old trucks. the 48 in my avitar gets drove every week and will get a work out this year. to get to the point, i am restoring a 51 f-2 for a customer and he had the flathead v-8 rebuilt but was not drivable with the rear end and 4 speed.i updated it to a 9" ford rear and half ton front spindles and brakes with 5 lug wheels. i used a flathead kit to put a 5 speed from a s-10 in it and used speedway motors kit. very good kit, but absolutly no instructions or any one in tech that could answer my questions, so, i was on my own.i put all the parts in and then tried to get the trans in alone. no way, just dont have the strength any more. so i figured out, thanks to the hamb to usr 2 1ft. pieces of all thread instead of short cut off bolts like some used. i put 2 at the top, got the adapter plate started, and it slid up and in place slkern snot! try it next time your on your on, it works great.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Looks like a good idea,,but lack of a floor helps!:D HRP
  3. gasmanm01
    gasmanm01
    i know thats the truth, i beleive you lurk around on here as much as i do. beats watching opra or the veiw
  4. HOTRODPRIMER
    HOTRODPRIMER
  5. 29AVEE8
    29AVEE8
    My old man taught me that one when I was a kid. I used to have the trans or clutch out of my '53 about once a month. We used long bolts with the head cut off and a hacksawed slot in the end to use a straight blade screwdriver in to tighten. Good for taking them out as well, gives you a little time to get ready for the weight.
    Mike
  6. OLD HEMI
    OLD HEMI
    I have those in my tool box . Thy run fron 1/4 to 5/8" and from 2 to 10 " in length. I used them when I worked as a heavy equipment mechanic. very handy.
    Lee
  7. Cliff Ramsdell
    Cliff Ramsdell
    Nice, I have used shorter ones over the years to get transmissions into place and they work great, as long as the clutch is aligned.
    Having to do things alone can be a problem sometimes. Getting the body off and on my Model A was always a pain with the engine hoist, my wife hooked me up though with a nice electric hoist and I mounted it to the garage rafters and roof, low weight limit, 800lbs but works great and is a 1 man job.
    Cliff Ramsdell
  8. tommy
    tommy
    I had to make some to get the trans in while hanging on the hoist. Like trying to shove a wet noodle up a bob cat's ***. I finally got Donnie to help me what a PITA.
  9. tfeverfred
    tfeverfred
    Great tip! I have had to swap ******s by myself and it's a PITA.
  10. There are never an HAMBers around to help here. Seesm that everyone has a life. :D
    I still use a floor jack and the missus now that the grandaughter is gone on to bigger n better things.
    Never the less the idea with the all thread is going into my ****nol for sure.
  11. Deeznuts
    Deeznuts
    Why didnt you holler at me, i woulda had that sum***** in there in about 2 seconds:eek:
  12. gasmanm01
    gasmanm01
    yea right. your wife probably had you doing laundry that late at nite or rubbing her feet
  13. jesse1980
    jesse1980
    Good idea. Wish I could have helped.
  14. richie rebel
    richie rebel
    yes sir,very good idea
