Hot Rods Needing brighter taillamp bulbs.
Discussion in 'The Hokey Ass Message Board' started by dickster27, Dec 8, 2016.
  1. dickster27
    dickster27
    from Texas
    I would like to know what taillight bulbs folks are using in '28 thru '39 tail lights. Is there a LED bulb worth a hoot? I bought a pair for the lights and the ones I purchased are not as bright as the bulbs in it now. Looking for suggestions.
    __________________
  2. manyolcars
    manyolcars
    I use the standard 32 candle tail and 50 candle brake. Never had one burnout in 23 years
    Bright?? 32/50 is the same as the headlight on my 1942 Harley
  3. BJR
    BJR
    Try painting the inside of the light housing white. One of the car mags did a test years ago and white reflected more light then silver.
  4. Joe H
    Joe H
  5. HiHelix
    HiHelix
    Here a very interesting piece on LEDs. This information will asisst you on choosing the correct LED and what kind of power source to use to acieve the result you need.... enjoy..
    http://www.theledlight.com/technical1.html
  6. I installed LED tail light bulbs in my 51' a few years back, big difference lot brighter
  7. BradinNC
    BradinNC
    Can't hurt to double check your grounds.
  8. 19Eddy30
    19Eddy30
    from VA
    X2. You will be surprised!
    upspirate likes this.
  9. southerncad
    southerncad
    I used "brite bulbs" from Ron Francis in my '49 and are plenty bright...don't know if he still sells em' :confused:
  10. dickster27
    dickster27
    from Texas
    Thanks guys for all your suggestions. I will try the white background as I now have the buckets painted silver.
  11. 50 customcoupe
    50 customcoupe
    Will the LED bulbs work with blue dots ? I have a '50 chevy with 12 volt system
  12. Yes
  13. jackandeuces
    jackandeuces
  14. Texas Webb
    Texas Webb
    Love to see pics of that Harley.
  15. Arominus
    Arominus
    LED's really are the way to go IMO. Less load and more light output in the needed spectrum. They also light up faster than incandecents buying you a little bit of reaction time from the guy behind you. If you have turn signals hooked up and you still have regular bulbs in your front turn signals on the same circuit, you shouldn't need to get a flasher until every bulb is LED on each side of the turn signal system.
    These are the brightest 1157's i know of that don't ****. A little expensive at $25 each but again, this hopefully keeps someone from hitting you. Remember, match the color of the LED to the LENS it sits behind. So red lens = red led bulb. This maximizes the output in the color that actually makes it out of your lens. A red led will be far brighter than a white one behind a red lens.
    https://www.superbrightleds.com/mor...on-28-smd-led-tower-bay15d-retrofit-car/1644/
    These are not as bright (but still are way better than incandecent) and will fit in any housing. $15 each
    https://www.superbrightleds.com/mor...on-36-smd-led-tower-bay15d-retrofit-car/1689/
    Flashers:
    https://www.superbrightleds.com/cat/flashers-load-resistors/
    wraymen likes this.
