Technical Needing small GM clutch disc
Discussion in 'The Hokey Ass Message Board' started by chlsnk, Aug 13, 2026.
  1. chlsnk
    chlsnk
    Trying to overcome the next hurdle mating a Lasalle transmission to a flathead. Needing a 9" clutch disc to work with the flywheel and pressure plate id like to run. 1 1/8" input 10 spline shaft.
    Local clutch shop is gone and some searching on rock auto hasnt turn up anything. Any ideas?
    Tim and chryslerfan55 like this.
  2. 19Eddy30
    19Eddy30
    from VA
    Option if not available I have in p*** drilled rivets
    & changed center's
    chlsnk and chryslerfan55 like this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
  4. 51504bat
    51504bat
  5. pprather
    pprather
    57tailgater, egads, SS327 and 2 others like this.
  6. Mr48chev
    The stock clutch for a 51 Chevy sedan was 9-1/8 inch. A lot of them had the heavy duty clutch though.
    Rock Auto shows a clutch kit while The Filling Station shows a disk.
    Or contact these guys Home Page I knew them as Waco Brake and clutch in the 70s when they were a block from the Silos that the home redo folks bought and is the Magnolia silos that everyone's wife wants to stop at. They may have a disk or they can rebuild yours. Screenshot (4025).png Screenshot (4024).png Screenshot (4026).png
    chlsnk likes this.
  7. 51 mercules
    51 mercules
    Centerforce 383824 Clutch Disc Size 9-1/8" 10 Spline By 1-1/8"?
    SS327, chlsnk and 51504bat like this.
  8. 51504bat
    51504bat
    Ft. Wayne Clutch used to be the place for clutches. Not so much anymore which is why I suggested Kentucky Clutch. But I've never dealt with them so they might not be able to help. Worth a call. IMO
    chlsnk and pprather like this.
  9. chlsnk
    chlsnk
  10. chlsnk
    chlsnk
    Thats actually the clutch kit I had my eye on but was worried about being 1/8" over size. Not sure if the 1/16" over hang would cause interfere issues or not.
  11. 427 sleeper
    427 sleeper
    1.233" is bigger than 1 1/8". I think I'd keep looking for the right disc, because the ones you're looking at won't work.
  12. Fordors
    Fordors
    Good catch @427 sleeper , I, as apparently most here glossed over the photos and never noticed the input shaft measurement. The OP wants a disc with an 1 1/4” x 10 spline.
  13. Mr48chev
    1-1/8 has always been 1.125 because .125 equals 1/8.
  14. pprather
    pprather
  15. Gus68
    Gus68
    from Minnesota
    I put a clutch disk that was just a little bit too big around for the pressure plate. Maybe an 1/8 inch, I don't remember. Anyway, I had a buddy with a lathe turn down the outter edge. It made a hell of a dusty mess, but it worked, and didn't take very long.
    chlsnk and 19Eddy30 like this.
  16. 427 sleeper
    427 sleeper
    Which is exactly why a 1.2335" input shaft won't fit a 1-1/8" x 10 clutch disc. He needs a 1-1/4" x 10 clutch disc.
    chlsnk likes this.
  17. chlsnk
    chlsnk
    I will say that's a spare rather rusty input shaft I took a quick measurement off of. Ill grab a better measurement this weekend off the actual transmission.
    Algoma56 likes this.
  18. Tim
    Tim
    from KCMO
    Would the interface of a 1/16 broader clutch be at the bellhousing? I can recall an aweful lot of posts about flathead to t5 bellhousing needing ground down for clearance. Is there enough meat to make room if you had to?
  19. AccurateMike
    AccurateMike
    I am using an 1/8" OS disc in a smaller PP. (7 vs. 7 1/8). The disc just barely touched some rivets on the PP. I did a combination of lathe grinding the edge of the disc and rounding one edge of the rivets. Fits now.. Kentucky clutch was helpful, even though I wasn't buying anything from them.
    50chevytx and Tim like this.
  20. rusty valley
    rusty valley
    Back in the 80's, I mated a datsun 240z motor to a volvo trans, for my 38 chevy. In those days, a good parts man would look thru the books....remember books? and figure out what will work. It ended up some studebaker disc, matched the spline count, but the lining was off by 1/8, or 1/4...I forget, but I ran it for years, maybe 30k miles, sold it to a buddy and it ran for another decade or so. Not sure the end of story.
    Also, the "clutch doctor" in North Branch Mn, a one man shop, will make anything you want. google em up
    Algoma56, chlsnk and 427 sleeper like this.
  21. chlsnk
    chlsnk
    Sage advice from another Kansan, Thanks.
  22. Message sent, chlsnk.
    Ben
    pprather and chlsnk like this.
  23. pprather
    pprather
    Clutch Doctor is located at 40167 Flink Ave in North Branch, Minnesota 55056. Clutch Doctor can be contacted via phone at (651) 674-4175 for pricing, hours and directions.
    Algoma56, Tim, rusty valley and 2 others like this.
  24. RICH B
    RICH B
    Clutch Doctor helped my friend come up with a pressure plate & disc to replace the direct drive on his vintage dirt track deuce. Came highly recommended and proved to be a good guy.
    Algoma56, chlsnk and Tim like this.
  25. chlsnk
    chlsnk
    Unfortunately a promising lead from fellow hamb member didn't produce the clutch disc needed. After further hunting on Rockauto I found a 80's 4cyl camaro disc that is 1/8" over sized I'm going to give a go. If it'd dosen't end up working I'll try something else.
    Algoma56 and Tim like this.
  26. dwollam
    dwollam
    I got my disc from a clutch place in Portland Oregon to fit the LaSalle trans and my Hemi flywheel and a diaphram Mopar type pressure plate (cover) I think it was 10" disc but don't remember but those guys could get or build anything. Portland guys should recall the business name.
    Dave
    Algoma56 and chlsnk like this.
  27. Fordors
    Fordors
    I’m confused @chlsnk . But OK, whatever you say.
    427 sleeper likes this.
  28. 19Eddy30
    19Eddy30
    from VA
    @chlsnk
    you could cut it down the 1/8
    chlsnk likes this.
  29. 427 sleeper
    427 sleeper
    It might fit the flywheel and pressure plate just fine, but it still won't fit the input shaft on the trans.
    Johnny Gee likes this.
  30. chlsnk
    chlsnk
    My real hang up with having something made up is this clutch being a "get me by" until I complete the engine that's being built for this car which will use a common 10" clutch.
    Tim likes this.
