Technical Negative Caster
Discussion in 'Traditional Hot Rods' started by ed ballingham, Mar 29, 2017.
About Caster
Poll closed Apr 5, 2017.
  1. too much or too little caster
    2 vote(s)
    100.0%
  2. maybe its OK
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. ed ballingham
    ed ballingham
    Building '23t with early style FED torsion bar front end , I have about 13 degrees negative caster with drag not installed and the weight of the car on it the tires turn in { narrow in front wide to the rear,
    does this seem normal. I know the torsion bar front end is not normal , tired of everything looking the same, thanks, Ed
  2. Fedman
    Fedman
    Yes, get the tie rod on it and it should be OK.
    Beautiful looking front axle ***embly for a FED,
    but are you sure the components and the sizing of them are good for the street?
    Or is this just a test to see if we are paying attention?
    Good Luck with your project and show us more Pics!
    X38 likes this.
  3. Boyd Wylie
    Boyd Wylie
    that would be fine for Drag Racing, but on the street will be difficult. Nearly impossible to back up.
  4. dreracecar
    dreracecar
    from so-cal
    Running tires with a rounded crown you need more caster or the car will push in the turns. Need more info, race? Wheelbase? Locked or open diff?
    Current front race tires have a flat crown and the caster is reduced
  5. deathrowdave
    deathrowdave
    from NKy
    You ever try to ride your bicycle as a kid with the fork turned backwards ? Not so easy ! Same effects as negative caster on your front axle . Simplest way for me to explain caster
    lothiandon1940 likes this.
  6. ed ballingham
    ed ballingham
    You're right this is no test , thanks for paying attention , I'll keep going and only go back to springs if I have to, had a Mark Williams Anglia spindles and axle, replaced the early Ford axle and spindles, thanks for your input,
  7. ed ballingham
    ed ballingham
    I guess I'll have to see how it goes now and change it later , I didn't think about backing up , thanks for the info,,
  8. ed ballingham
    ed ballingham
    With my rounded crown tires I will need more negative caster?,,, No race about 120 inch wheelbase with Ford 9 inch posi, thanks
  9. ed ballingham
    ed ballingham
    Thanks for the info the simpler the better for me, thanks
  10. van Dyck
    van Dyck
    Negative caster? You're talking positive caster here.
  11. midroad
    midroad
    Can we have a pic of the whole car? That front end is just a tease.
  12. Kerrynzl
    Kerrynzl
    You are correct! Positive caster [as per photo] has the top leaning back
  13. rooman
    rooman
    The springing medium has nothing to do with the effect that the caster has on the steering. With no tie rod in place the wheels will toe in due to the relationship between the king pin axis and the tire contact patch. The comments re "negative caster" are correct--you have positive. If you did have negative caster the wheels would have a tendency to toe out If your "no race" comment means that you are planning to drive this on the street the caster needs to be reduced to 7-8 degrees at the most or you will have the backing up issues mentioned by Boyd. You will be able to do it but it will take a tighter grip on the steering wheel. You will also need to be careful in tight turns as the wheels will have a tendency to fall into the turn--not as bad as a dragster with 30 degrees caster but it will happen.
    The early Ford spindles are definitely a better deal for a street driven car but I an with Fedman in that the torsion bar tube (and the front frame rails) look a little undersize for the rigors of street use which is way harder on a car than any drag strip.
    Roo
    lurker mick likes this.
  14. hog mtn dave
    hog mtn dave
    Sure looks good though.
  15. christmas tree
    christmas tree
    I see no provision for shocks and this is not a good set up for street. Great workmanship
  16. ed ballingham
    ed ballingham
    Yes you are right , sorry for the confusion,
  17. ed ballingham
    ed ballingham
    Thank you for the detailed info I will make some changes,
  18. dreracecar
    dreracecar
    from so-cal
    What type of steering box?? The more caster what effect it has is a balencing act on a tightrope. as you can see by your first pic is the wheels falling over, if the caster is "0" the wheels would not flop and with caster you are constantly trying to keep the wheels from falling over, and lifting the front end weight coming out of a turn at slow speed. Compounding this is that the wheel center is far out from the king pin so the whole thing acts as leverage. Dragsters get away with more caster because the front end weight is around 400# and you are more into the 7-800# range and thats a lot to lift up. No more than 9* and any more you will need power steering ***ist
