Technical Neutralize OSPHO?
Discussion in 'The Hokey Ass Message Board' started by 41Helen, Mar 3, 2022.
  1. SS327
    SS327
    After you put the chicken in the burlap bag how many times do you have to swing it over your head? Does it matter what kind of chicken?
  2. pirate
    pirate
    from Alabama
    I’ve used a fair amount of Ospho but do not have a lot of experience with large panels. For brackets I make or other parts I clean them well to remove heavy rust then spray Ospho on using a trigger type spray bottle like an empty Simply Green bottle.I let the parts dry well. If there is a residue or build up I might rinse with water and wipe dry with a cloth then let air dry. I have used Scotchbrite to smooth areas also. That’s it! I then prime or paint directly. You want to maintain the iron phosphate surface to protect from further rust and iron phosphate provides and excellent surface for paint or primer. Some Mil Specs require iron phosphate treatment before primer or paint.
    gimpyshotrods likes this.
  3. gimpyshotrods
    gimpyshotrods
    Barred Rock, or Rhode Island Red.
    6-times.
    SS327 and alanp561 like this.
  4. mikhett
    mikhett
    from jackson nj
    The Ospho instructions doesn't mention neutralizing it!
  5. AngleDrive
    AngleDrive
    from Florida
    From house of Kolor tech sheet
    NOTE: PLEASE REFER TO SANDING GRIT RECOMMENDATIONS FOR BARE METAL AND OLD FINISH SANDING. NOTE: DO NOT USE ANY ACID BASE PRODUCTS SUCH AS SELF ETCHING PRIMER, ETC. UNDER THE KP2CF PRIMER. THIS WILL ALMOST CERTAINLY CAUSE AN ADHESION PROBLEM. NOTE: IF YOU FIND IT NECESSARY TO USE A METAL CONDITIONER TO REMOVE RUST, ETC., BE SURE TO THOROUGHLY CLEAN AND NEUTRALIZE THE TREATED AREA FOLLOWING THE CONDITIONER MANUFACTURERS RECOMMENDATIONS, USING OUR KC20 POST SANDING CLEANER WITH A MAROON SCUFF PAD TO INSURE ALL ACID RESIDUE HAS BEEN REMOVED BEFORE PRIMING. IF NOT, THIS WILL ALMOST CERTAINLY CAUSE AN ADHESION PROBLEM.
    Rich796 likes this.
  6. AngleDrive
    AngleDrive
    from Florida
    I have never had a problem with ospho either
  7. alanp561
    alanp561
    Clockwise, or counterclockwise? Just trying to cover all the bases;).
    SS327 and mrspeedyt like this.
  8. belair
    belair
    If Gimpy says a rooster will pull a freight train, I would hook it up and go.
    SS327 and gimpyshotrods like this.
  9. gimpyshotrods
    gimpyshotrods
    Counter.
    Never go the other way!
  10. mrspeedyt
    mrspeedyt
    Screenshot_20240619-173051.png think on my old cad i'll just sand the old paint down and let it rust. it's halfway there allready.
    alanp561 likes this.
  11. Rich796
    Rich796
    That's pretty much true for all of HOK's primers/sealers. I don't think they have a single one. That's recommended for use, on top of any acid based cleaner or converter.
  12. gimpyshotrods
    gimpyshotrods
    So yeah, a quick read of this particular manufacturer's instructions would have prevented the drama.
  13. gimpyshotrods
    gimpyshotrods
    But the HOK instructions did....
