New 409 ALUMINUM Blocks!
Discussion in 'The Hokey Ass Message Board' started by spinout, Feb 3, 2010.
  1. spinout
    spinout
    from Dallas, TX
    World Products is now making new 409 blocks....ALUMINUM! Just read this in the Engine Builder e-Newsletter. Here is the link to follow:
    www.worldcastings.com Spinout
  2. stretch 1320
    stretch 1320
  3. 65 impala
    65 impala
    cant wait to see the pricing on this stuff prob be your right nut and left foot
  4. If they are reasonably priced I might have to buy me one!
  5. There has been some threads on this in the past with a lot of valuable info and answers about availability and cost. I believe Mr. Walden has had a lot of input on the design and launch of this venture.
  6. yellow wagon
    yellow wagon
    from WI
  7. lowelife
    lowelife
    Alright, that block with Edelbrock's heads and a 6 carb offy intake would look wicked!
  8. propwash
    propwash
    from Las Vegas
    SuhWHEEEEET!!
  9. The Brudwich
    The Brudwich
  10. Candy-Man
    Candy-Man
    Any pricing as of yet?
  11. Max Gearhead
    Max Gearhead
    from Wisconsin
    Looks like about 5 grand!:eek:
  12. 5 Grand, I will p***
  13. Zeke
    Zeke
    Screw that..I'll stick with the 235 for now.
  14. temper_mental
    temper_mental
    from Texas
    I wanted a aluminum block until I looked into pricing.
  15. Shaggy
    Shaggy
    from Sultan, WA
    Somebody else is making 409 blocks too, someone also said the world blocks are just remachined big block castings, I dont know anything about 409 myself, but just relaying info i read on here a couple months back
  16. yellow wagon
    yellow wagon
    from WI
    Bob Walla is going to produce a from-scratch, all aluminum block. He already casts HP aluminum heads
  17. holeshot
    holeshot
    from Waxahachie
    SPINOUT...there's no such thing as REASONABLE when it come's to aluminum block's. and i'am very surprised there's a market for 409 engines. realy the 396-454 mill's are much better, in my view...POP.
  18. Candy-Man
    Candy-Man
    That is true the new generation V8's are better in the performance department, however; do you have the great looking 'W' heads/valve covers? Some times it is not just about performance. Now saying that, have you ever watched Mr. 409, Wooly Bully, etc. launch their cars and the times they are turning? I would put any BB up against their cars with the same build......
  19. Never2low
    Never2low
    "Damn, now I know I put that hacksaw somewhere, God I wish my nut would stop hurting....maybe he's just lonely now.....:D"
  20. 49ratfink
    49ratfink
    excellent. the stupidly rich can now blow 5 G's on an aluminum 409 block. that ought to impresss the hell out of those guys with the aluminum Ardun head flatheads.
  21. panic
    panic
    Who will be the first to find out what they did wrong....?
  22. rockguy92
    rockguy92
    I agree with 49ratfink - I dig the 409, but 5 grand. JEEEEZ. That is more than I have tied up im my whole car.
    The Rock
  23. 47Hudson
    47Hudson
    Barry Camp has #1, Lamar Walden is using it to replace the used up cast blocks he keeps breaking. It will be a lot cheaper in the long run, but then again there are not a lot of people running mid 9's in th quarter with their 409 powered 62 Bubble Tops like Barry!:D
  24. stretch 1320
    stretch 1320
    Hell for 5grand you can buy a Donovan 10.200x4.600 aluminum block delivered to your front door anywhere in the US! And I'm sure you can build alot more inches with that one, but the 409 block looks really cool!
  25. Brad54
    Brad54
    from Atl Ga
    The people on here that are *****ing about the price have never looked into actually building a 409. Try buying a 409 truck block some time... $1200 gets you in the door, if you find a deal on one. P***enger car blocks start at $2500 and go up from there. Then you've got the machine-shop costs, which isn't going to be cheap. At a bare minimum, you'll have $3,000 in a bare block with 2-bolt mains, and an area between the deck and the freeze plugs that's prone to cracking.
    Sleeve a cylinder (which is pretty common), and maybe add some 4-bolt caps and ARP studs, and now you're at what this new block is going to cost ready to go.
    You'll actually end up saving some money with the new World block: It has dual oil pan rail mounts, so you can run either an original 409 pan (expen$ive) or a standard big block Chevy pan, which is available at every swap meet. The Al. block also uses a BBC timing chain cover, which are a dime a dozen, versus trying to find one of the two styles of 409 t-chain covers, that are getting harder and harder to come up with.
    You'll also be able to use a BBC cam, rather than the special 409 cams.
    Stronger, lighter, and cheaper in the long run, plus it comes ready for 509 cubic inches.
    I know so much about these because I watched Lamar build the prototype and did the story on them for Super Chevy, and I've seen the two that have been cast down at Lamar's shop.
    -Brad
  26. Brad54
    Brad54
    from Atl Ga
    Lamar said the block will go over 609 cubic inches.
    -Brad
  27. Brad54
    Brad54
    from Atl Ga
    Barry Camp. But this ain't Lamar's first rodeo. He's been building '09s since he raced one in A/Gas in the early '60s... including one with twin turbos and a billet block and billet heads he made in the '80s.
    -Brad
  28. Brad54
    Brad54
    from Atl Ga
    No, they're not. They're entirely new, dedicated castings. Lamar STARTED with a World BBC for the prototype work: cam and crank location, oil p***ages, bore spacing, etc. The deck is completely different than a BBC, and Lamar thickened it up. The water pump mount is 409, and it has a dual oil pan rail for 409 or BBC.
    -Brad
  29. slammed
    slammed
    Coming soon: Twin turbo'd, stroked, polished top-to-bottom-inside-out 1500 HP Power Tour Top Ten Pick! But really, a blown (12-71) 600 cu '409' FED would rule. Hey Poteet, whadda ya say?
  30. I don't see the market for them... except the more money then brains crowd. the main point of an aluminum block is weight reduction. that being said most of the cars that would get a 409 really don't have any good weight distribution anyhow. and at 5g's thats insane... Hmm howbout a aluminum 409 with cast iron heads. Call it the upside down 409
