New 6 Volt Toy!
Discussion in 'The Hokey Ass Message Board' started by S2X01, Aug 31, 2013.
  1. S2X01
    S2X01
    So...I recently acquired this gem for next to nothing!!
    Anybody know what it might be from? Is there any way to wire it up to my Dodge?(6V positive ground system)
    Even if not....it's pretty sweet.
    Here's the other end of it.
    If I can get it to function...that would be awesome!!
  2. no, it wont work for you, send it to me.
  3. S2X01
    S2X01
    Ha! Nice try...I'll keep it either way. Money well spent in my opinion.
  4. Tach plus hood meter?
  5. S2X01
    S2X01
    Hood meter?
  6. Leviman
    Leviman
    Do you know what the pins go to? I'd imagine you have a positive, negitive, and a coil signal. If you can figure out which one is which and how to select the pulse for 4,6,8,etc. If you can figure out which is which, then it's simply a case of connecting the dots.
  7. F&J
    F&J
    Most likely truck, as it has high and low shift points, as well as hourmeter
    I'd bet it needs a transmitter.
    There is supposed to be a website to ID those SW units and gauges
  8. S2X01
    S2X01
    Which is the difficult part. I'm good with electrical...but that is WAY beyond me.
  9. Jalopy Joker
    Jalopy Joker
  10. 302GMC
    302GMC
    from Idaho
    The plug fits the wiring harness from the sending unit which is sandwiched between the distributor & cap.
  11. chromeazone
    chromeazone
    4500 RPM ?
    Probably for an old John Deere riding mower or Johnnie Popper. Maybe a chainsaw!!
    Har! Har!
  12. Saw that ***le and thought my wife was posting....
  13. 40FordGuy
    40FordGuy
    SW tachs used a transmitter.....The plug was likely mated to it. It's a cool item,....I'd keep it !
    4TTRUK
  14. S2X01
    S2X01
    Hmmm...so now I need to find a transmitter.
  15. ROADSTER1927
    ROADSTER1927
    Here are some pics of a complete setup for a late flathead. The part you have is the easy part, the plugs for the cable are kind of unobtaineum and the senders are different for the distributor you want to run. You also need the extension clips for the cap hold downs. You can pm me if you need any more info. Gary:)
  16. S2X01
    S2X01
    Wow...so there's no way to just run it off the coil like a newer 12v tach?
  17. ROADSTER1927
    ROADSTER1927
  18. S2X01
    S2X01
    Well ****. Looks like I've got a new decoration.
  19. scrappybunch
    scrappybunch
    from nj
    At least it will look cool when the car is parked.
  20. S2X01
    S2X01
    Just for fun...I pulled it apart. Inside is 4 coils, some caps, and 3 wires. Green, black, and white. I'm gonna run this to my electrical guy up the street and see what he thinks.
    I guess I'll probably call SW also....
  21. Ya. Hood meter.
    That's how you spell hour meter after drinking rum.
  22. S2X01
    S2X01
