Projects New 63 Lesabre wagon
Discussion in 'The Hokey Ass Message Board' started by Donuts & Peelouts, Oct 18, 2018.
  1. A soda
    5 vote(s)
    16.1%
  2. A candy bar
    3 vote(s)
    9.7%
  3. Save it
    23 vote(s)
    74.2%
  1. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Hope you been good, I knew you would like the Buick Ray.
    Hnstray likes this.
  2. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Does that mean I would be either forced to use the speedo/front tire system or not have a speedometer at all?
    How about an aftermarket piece or digital device that can figure how fast the car goes as ugly as that sounds with such a nice looking dash I really don't want to add much if anything to the dash.
    I had a ot car that had a swaped sbc350, and I used an app on my speedometer app on my phone that was very accurate, and this was 2012.
  3. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Hey thanks man, I know some times i get off topic though. Im still learning and need a traditional slap from time to time.
    scotty t likes this.
  4. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thanks.
    Ill be adding all progress and questions on this thread.
  5. Hnstray
    Hnstray
    from Quincy, IL
    A GPS unit of some type would be my ‘go to ‘ solution. I use a portable Garmin unit in everything I drive.
    Donuts & Peelouts likes this.
  6. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Or how bout taking a th400 case from the 70's and swaping the switch pitch guts?
    Hnstray likes this.
  7. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thanks and me too.
    s55mercury66 likes this.
  8. slim38
    slim38
    from Sudan TX
    Congrats on car and familia! Them babies are a true blessing for sure.
  9. There are various Vehicle Speed Sensor driven converter units that will drive a mechanical speedometer via a motor. You might contact one of them and see if they have any solution utilizing driveshaft magnets and a remote VSS if you are heart set on using that transmission. Or pull the tailshaft and see if the output shaft has provision for a speedo drive gear. If so, add the gear and find a tailhousing to match the main output shaft. Or swap that transmission for a non Oldsmobile TH400 or look for a TH200-4R and have a four speed with lockup converter, there are kits to electronically operate the lockup converter, I would do that instead of adding a GPS speedometer. I'm of the camp if the gauge is in the dash it has to work.
    Hnstray and Donuts & Peelouts like this.
  10. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thanks Slim, have you a great weekend brother.
    slim38 likes this.
  11. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thanks alot I'll look into my tailshaft to get an answer. Thanks for your help. And I too desire a functional original dash even if whats under the hood is not.
    Hnstray likes this.
  12. F.O.G
    F.O.G
    from Pacific,Mo
    You can't use the front drive speedo without the spindle that is hollow so the cable can go through it to the driver in the dust cap.
    Sent from my SM-J320V using The H.A.M.B. mobile app
    loudbang and Donuts & Peelouts like this.
  13. F.O.G
    F.O.G
    from Pacific,Mo
    I have the same situation on my bucket with the TH400, so I use an APP I downloaded with a speedo, works fine.
  14. How about this. "Cl***ic Automotive Innovations". I am an old fart that has not learned to link. Google works
    Ben
    Donuts & Peelouts and loudbang like this.
  15. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    Thanks Ben, thanks for the help. More "old farts" have helped me than any "young poop" has.
    loudbang and firstinsteele like this.
