New A 318 (Poly) Intake Manifold
Discussion in 'The Hokey Ass Message Board' started by ajmopar, May 6, 2013.
  1. lippy
    lippy
    from Ks
    I believe everyone has sold the old poly short. For all around street driving and torque, which moves weight, witch is what it's all about. The poly cannot be beat. If half the aftermarket would have put parts engineering in the poly, the small block chevy would not be what it is today.JMO Lippy
  2. 73RR
    73RR
    Yes, call-write-email CPM.
  3. tubman
    tubman
  4. Desmodromic
    Desmodromic
    Slightly off topic - info wanted - there seems to be two different poly head configurations. The early (?) ones have a very pronounced "scalloped" shape, similar to a Chevy 348. Later heads are less so, more like a "sawtooth" shape. I'd like to find an engine with the earlier version. What year/model car should I be looking for? Are the blocks interchangeable? The manifolds? Will this "new" manifold fit the earlier heads? Are there any aluminum valve covers available?
    Thanks!
  5. Relax354
    Relax354
    Thanks 73RR I will call them. Going to do a 3.58 stroke poly.
  6. Ray Bell
    Ray Bell
    from Brisbane
    A late reply, I hope you're still looking...
    The other Poly engines, as you describe, are Poly versions of the older-style Hemi engines. They don't interchange at all. Used in Dodge and De Soto, if I recall correctly, about 1958, 1959. This manifold won't fit them as they have separate valley covers.
  7. This intake is for 1957 to 1966/67 277/301/313/318/325 A series Plymouth/Dodge Poly, this engine has the sawtooth shaped lower edge to the rocker covers, alloy rocker covers are available from Alan Fountain in Oz and CPM in the USA, each slightly different but only for the 57-67 Poly....CPM has cams, stroker kits, pistons, etc available........andyd
  8. George
    George
    Dodge hemi based Polys were also used in Plymouths, '55 & some '56s.
  9. Friend of mine is looking for a 3 duce manifold for a 318 Poly motor. Anyone have an idea where he can get a gold of one?
  10. swifty
    swifty
    They turn up on eBay from time to time. My son has bought a few off there, mostly Edelbrocks but he did get one Weiand which is in my shed now!
  11. 340HilbornDuster
    340HilbornDuster
  12. earlymopar
    earlymopar
    Keep in mind that there were (2) 3-deuce manifolds made for the Poly 318, one from Edelbrock and one from Weiand. The Edelbrock P600 is the better piece and is a dual-plane. The Weiand is a single plane. I have a P600 for sale that will come with a 3-deuce to single 4-barrel plenum I made. PM me here.
    - EM
  13. 1962 dodge lancer
    1962 dodge lancer
    from joliet, il
    very nice about time somebody started hopping up early 318 mopars !!!
