Projects new again, need 1950 merc flathead ignition advice
Discussion in 'Traditional Hot Rods' started by 29A-V8, Oct 29, 2021.
  1. 29A-V8
    29A-V8
    from wyoming
    Have 50 merc flathead, want to put mechanical advance dist in, read a post here some time ago about modified sbc or mopar distributors. can anyone direct me to info on purchase or have one modified?
    thanks
  2. 51504bat
    51504bat
    I'm running a mechanical advance SBC distributor in the 8ba in my '39 p/u. Bubba here on the HAMB did the conversion but he is no longer doing them due to health issues. Bur CharlieNY on the Ford Barn does them and maybe Michael at Third Gen but not 100% positive about Third Gen. Very happy with the Chevy conversion.
    29A-V8 and lothiandon1940 like this.
  3. gary macdonald
    gary macdonald
    Go to the Ford Barn forum . Choose flatheads and one member makes them
  4. redoxide
    redoxide
    I have a bubbas ignition in my 8ba , runs great but im not sure they arestill doing them .?
    Recently did some work on my buddies chevy truck rewiring and other work. Doing the ignition was a wee bit of a light bulb moment for me .
    He runs an electronic Pertronix unit in the chevy dizzy. He has also did away with the mechanical advance and used another electronic unit called an Amethyst . It reads the vauum signal and advances or retard the ignition timing . Its also programmable for max advance and tunable advance curve .
    The light bulb moment was realising that I can use the Amethyst set up in the old flathead distributor .
    It wouldn't be necessary to convert the original point to electronic as the points just become a switch , the condenser is binned as the "spark" is controlled through the Amethyst unit .. It wouldn't hurt to shift the points for a pertronix unit but that's added cost.
    I haven't gotten around to looking any further into this set up yet, but I've seen it in action and think that its a good call for the 8ba dizzy that relies on a matched carb vacuum .. you can discard the Ford 94s and fit 97s , lock off the bob weights , divert the vacuum to the amethyst , and use the original contacts ( minus the condenser) as a simple switch :)
    here is a link to the Amethyst unit
    http://www.aldonamethyst.co.uk/
    29A-V8 and dmar836 like this.
  5. 51504bat
    51504bat
    Here is the info on CharlieNY from a post on the Ford Barn. Charlie & Alice Schwendler at Canfield '17(1).jpg
  6. Deuces
    Deuces
    And he drives a Chevy truck...:)
    Truck64, lothiandon1940 and blowby like this.
  7. 51504bat
    51504bat
    And he has good taste in beer.:cool:
  8. 29A-V8
    29A-V8
    from wyoming
    Thanks for the replies,
  9. 29A-V8
    29A-V8
    from wyoming
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I changed your title so you will hopefully get more help
    Desoto291Hemi likes this.
  11. 29A-V8
    29A-V8
    from wyoming
    thanks Im trying to figure it out on the fordbarn, should I just post the question in flatheads?
  12. Budget36
    Budget36
    Early V8 section
  13. tubman
    tubman
    I am partial to "flattop" Mallory's, as they have "the look". I have run just about every kind of distributor in flatheads over the years (including converted GM units, both with and with out vacuum advance), and really haven't seen much difference, so I go with the Mallory's for looks alone. In this vein, it's just as easy to convert an aftermarket distributor (Mallory, Accel, or even MSD) as it is a GM unit, so this expands your choice even more. (SBC Mallory's are a LOT cheaper than one originally intended for a flathead.)
    I don't particularly like any kind of aftermarket electronic ignitions, as they have the nasty habit of failing totally and unexpectedly, leaving you stranded. A conventional points unit almost always will start to degrade, giving you plenty of notice and the opportunity to limp home. 6 volt Pertronix units are particularly bad this way, and paired with a generator with their "dirty" power, are a ride home on a flatbed waiting to happen.
    And despite what many say, a stock Loadamatic in good condition works exceptionally well on a stock engine.
  14. 19Fordy
    19Fordy
  15. oldsman41
    oldsman41
    Mallory dual point is what I have in my merc works great
  16. 29A-V8
    29A-V8
    from wyoming
    Thanks for the help and the title change. us old guys are not as good at this computer stuff as some of the young ens. got more help too!!!
    210superair and Moriarity like this.
  17. 29A-V8
    29A-V8
    from wyoming
  18. 29A-V8
    29A-V8
    from wyoming
    Appreciate all the help and ideas, nother reason I got back on the hamb
  19. 19Fordy
    19Fordy
    I converted my Mallory dual point to electronic with Pertronix kit and it
    works even better.
  20. 29A-V8
    29A-V8
    from wyoming
    Got a Mallory dual point looks great. pulled the original and dropped the Mallory in, was about 3 degrees off on initial timing. put the light on it, runs like it new.
    Good advice thanks
