Hot Rods new bodies
Discussion in 'The Hokey Ass Message Board' started by rer_239, Jul 25, 2018.
  1. rer_239
    rer_239
    are the new bodies (i.e. brookville) bodies ***embled with rivets or are they welded together?
    thanks
    rer_239
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Welded together! But you can buy them un ***embled in some cases.
    KK
  3. 55styleliner
    55styleliner
    I could use one, I’ve worn mine out lol
  4. Never2old
    Never2old
    from so cal
    Henry used rivets for a reason.
  5. A Boner
    A Boner
    Does Brookville use mig or tig?
  6. Atwater Mike
    Atwater Mike
    Production shops favor mig
  7. X38
    X38
    Which bodies? Deuce or A?
  8. GordonC
    GordonC
    Henry may have used rivets for a reason but frames weren't boxed back then either!;) Theres nothing wrong with a welded body.
    afaulk likes this.
  9. Spot welded with resistance welding
    I don’t remember rivets on floor pieces/braces
    But most of the ones I worked on were dis***embled
  10. rer_239
    rer_239
    A bodies
  11. krylon32
    krylon32
    from Nebraska
    When we ***embled the first 32 roadster bodies at my shop we bolted the cowl top to the cowl sides and bolted the upper and lower deck lid panels to the 1/4s. spot welded the floor pan to the sub rails, spot welded the wheel well area
    to the sub rails, welded the trunk braces and other braces to the body and sub rails. welded the cowl top to the sides in the front channel where it was factory welded. Put a lot of small welds in hidden areas to strengthen the body. We also did 1/4 panel braces with turn buckles and an X frame behind the seat to make the body more rigid. Since I've started buying factory ***embled bodies I've noticed more welds and the floor pan is riveted to the sub rails like the factory. I've only had an A roadster pu body 15 yeara ago and can't remember how it was ***embled?
    Hnstray likes this.
