Technical New camshaft
Discussion in 'The Hokey Ass Message Board' started by Steve Webb, Oct 12, 2022.
  1. Steve Webb
    Steve Webb
    I have a 40 Chevy coupe with a 331 small block Chevy. Aluminum heads, Elderbrock intake with a Quickfuel 600 cfm, vacuum secondary. It has a 700R4 with Corvette performance parts,
    9 inch Ford rear with 411 gears.
    Question; want a cam with a good lope for that sound and more horsepower. What would be a good fit and I drive this car on the street. It also has AC. It has a mid range rv camshaft in it right now and can't handle the carb. Don't want to buy another carb.
    Thanks in advance.
  2. larry k
    larry k
    Call your cam company , they will know better than we would !!!
    SS327, AHotRod and Truckdoctor Andy like this.
  3. 427 sleeper
    427 sleeper
    Isky Z-25 or Z-27
  4. Bob Lowry
    Bob Lowry
    I'm jealous...here is my '40 from my teen years in Phoenix.in 1965, good times....I had a 301" in
    it with a Sig Erson 990B...310 duration, 520 lift...needed to idle at 1800 to keep running.
    Wicked sound though. I like 106 loc, with 490 lift and 300 duration cams. Good advice above
    to call the cam company. The lower number of loc, the more lopey it will be, but somewhat
    less streetable...but so what?
    Algoma56 and seb fontana like this.
  5. big duece
    big duece
    from kansas
    The Corvette "151" cam was a good one, likes 11:1 compression though.
    Deuces likes this.
  6. gimpyshotrods
    gimpyshotrods
    Something roller.
    joel, Truckdoctor Andy and SS327 like this.
  7. sunbeam
    sunbeam
    I'm old school 097 Duntov great sound 228 and 230 at .50 108 centers .400 lift and anymore good solid lifters are easier to find and they held lash setting well. and a power band well toward 7000 rpm
    Bob Lowry likes this.
  8. Moedog07
    Moedog07
    L-79 or Summit Racing Camshaft №.1785
    I have used both with an automatic transmission. The Summit cam's specs are close to the L-79.
    Deuces, Algoma56 and Bob Lowry like this.
  9. Blues4U
    Blues4U
    from So Cal
    Something's not right here. "Can't handle the carb"? It's a vacuum secondary, it will only run on the primaries when you open the throttle until there is enough vacuum to open the secondary. Changing the cam to one with more overlap is not going to improve this condition. I suggest you get it running right first before changing the cam.
    ClayMart, jaw22w, jimmy six and 7 others like this.
  10. seb fontana
    seb fontana
    from ct
    I think the OP means he has enough carb but needs more cam to get more power and some "sound"; he has enough other good parts. I too would recommend a roller for less worries at break in, need current day cam suggestions or start calling Cam manufacturers as having an auto trans have to worry about converter some.
    joel and Bob Lowry like this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    There ya' go with those pesky details !LOL:D
    jimmy six likes this.
  12. AHotRod
    AHotRod
    Pick up the phone and call Bullet Cams if you want to do this the right way.
    Call Bullet Racing Cams at (662)893-5670.
  13. Nailhead Jason
    Nailhead Jason
    You need to tune the carb properly. There is no reason it should not be able to handle a 600 cfm carb. I get 19 mpg on a 10.3 to 1 283 Chevy with a 600 cfm carb. Tune the carb. You might be surprised at how it sounds after it’s dialed in.
    ClayMart, AHotRod, Tim and 1 other person like this.
  14. 1971BB427
    1971BB427
    from Oregon
    When I was putting together my '39 Chev with SBC 350 engine, 700R4 trans, and 3.73 rear 8.8" Ford axle; I contacted numerous cam companies for help. All but one sent me to their online form to fill out. Howard's Cams tech spent time on the phone with me, and directed me to the camshaft I bought.
    My engine is fairly stock 1990 flat top pistons, with Dart 180 heads, Edelbrock Performer RPM intake, and a Quick Fuel 650 double pumper. The camshaft is a roller cam with .525"/.530" lift, duration 278/286, and LSA of 109. It's a somewhat rowdy idle, but works great with my automatic and the 2500 stall converter. Pulls extremely hard off idle, and runs up to around 6200 rpm's strong. I had new roller lifters, so just needed a camshaft. Any lift over around .490" will require enough valve spring to handle high lift, but all the aluminum heads seem to come with springs to handle this lift.
    I'd call Howards Cams and talk with them and see what they recommend for your build.
    Truckdoctor Andy likes this.
  15. big john d
    big john d
    from ma
    had the same good personal service with howards
  16. 38Chevy454
    38Chevy454
    Just get the catalog, turn to SBC page, and go to bottom of the page. That will give you a radical idle.
    Or realistically a cam with 220-230 duration at .050 lift is probably what will work good. Roller if you can afford it is better. That duration should still have enough for 700R4 to work on highway, but also nice strong idle sound without being too much for the street.
  17. lippy
    lippy
    from Ks
    I stopped reading when you said you wanted a lopey idle and you have an automatic.
    jimmy six, Fordors, bobss396 and 3 others like this.
  18. Deuces
    Deuces
    Yep! I also believe in fine tuning the carb... Try switching to the next lightest vacuum secondary spring and give that a try....
  19. Blues4U
    Blues4U
    from So Cal
    Haters will be haters........ :D
    2OLD2FAST, Just Gary and 1971BB427 like this.
  20. jimmy six
    jimmy six
    Fix what you have. A mid RV cam is normally a 260-268 and should be fine with an automatic. But I’m thinking there are other problems in the total build that were not thought out.
    With 4.11 gears you should be kicking *** with a 600 carb. I’m guessing the aluminum heads have 2.02-1.60 valves and 64 cc chamber, and your pistons are flat top. That’s not a lot of compression on a 327. If your chambers are 58cc then your good and in might be the cam position. 6*s advancing the cam will wake the engine up a lot if it’s set straight up or possibly retarded.
    I’d be checking everything you have first. Good luck.
    Deuces and Just Gary like this.
