"New" Daily Driver Pickup "Project"
Discussion in 'Off Topic Hot Rods & Customs' started by guthriesmith, Dec 30, 2025.
  1. rockable
    rockable
    255/70R-15 rear 255/60R-15 front
  2. guthriesmith
    guthriesmith
    Thanks! That’s the size I was considering on the front as well. I was thinking 275/60’s on the rear though just to have a little wider tire. That’s only about an inch different in height where looks like you have a couple inches difference.
    Bill's Auto Works likes this.
  3. guthriesmith
    guthriesmith
    1/2 a coil is not enough…. Rolled it back and forth, bounced it, etc. I think I may cut another 1/2 coil tomorrow.
    just Matt, Tim, swade41 and 3 others like this.
  4. Taboo56Chevy
    Taboo56Chevy
    On the front of my truck I ended up doing half a coil on 2" lowering springs along with the 2 1/2" spindles. Rear is a coil/truck arm setup so its not really applicable with the squares leaf springs.
  5. DEFINITELY!
    Right now it looks like either there is a fat Mother In Law in the bed or you are one of those goofballs with all the lights under their trucks looking up into the sky! LOL
    One question though Jeff....With the rear that low, will you be able to go pick up your next engine & trans for the next project without the tires rubbing the tops of the rear wheel wells?
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
    SS327 likes this.
  6. guthriesmith
    guthriesmith
    Well, that's a good question Bill. :D I am definitely not going for that "Carolina squat" look. :eek: And, I am currently concerned some with hauling loads.
    It sort of hit me this morning while brushing my teeth that I should get all the spare parts out of the bed to see how much that is weighing down the rear currently. Probably not as much as a fat mother in law, but there is likely 200 or so pounds of stuff in there currently. Also, I think that the rear springs on this thing may be sagging quite a bit. So, the answer is I still have work to do which will likely include c-notching the frame, a set of helper airbags to both haul loads and pull my car trailer as well as maybe considering swapping those rear springs for some better ones. I know I will get there with something both cool and practical, but it sure isn't there yet. One limiting factor on these is how low you can go in the front before the front tires hit up inside the wheelwells. Best I can tell, the limiting factor in the rear is when the rearend hits the bottom of the bed floor which should happen before the tires ever hit. Anyway, probably not much going to happen this week since my wife and I are taking a short trip to Louisville.
    More to come. :)
  7. Careful of that slippery slope!
    Ben
  8. guthriesmith
    guthriesmith
    No kidding... If this hot rodding thing was easy everyone would do it right? :D
    I may have to pull out the old "engineering" hat to help solve the problem(s). :rolleyes:
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    cut another full coil.....
    BigJoeArt, Sharpone, Tim and 4 others like this.
  10. slider-ok
    slider-ok
    from oklahoma
    I'll be the naysayer, Get it running and finish up the other projects. Once all those are where you want them and you've used the truck to get parts for the others then spend the time to slick out the truck....it's just a chevy.
  11. guthriesmith
    guthriesmith
    Yea, yea, I know Fred. Hoping to be done with this “project” by the end of this month. Not planning to go nuts on it at all. Other than lowering it, it is mainly just getting it running and driving. I will probably wash it to get all the greasy handprints off. :D
  12. Nostrebor
    Nostrebor
    I'm with Moriarity... you are a coil away from the win.
    Sidebar: Is it wrong that I am a bit sentimental for the knock-off Centerlines on there? I am really getting that 80's high school parking lot vibe with those on it!
  13. guthriesmith
    guthriesmith
    I could make you a good deal on those wheels. :D Oh, and I have had similar thoughts. With some decent tires, they wouldn’t be bad. They are basically the same wheels that I had on a couple vehicles in the 80’s…. I just remembered the brand of the first wheels I ever bought new like that for my 71 Monte Carlo when I was 15. They were American Eagle and they came from our local Super Shops. :rolleyes:
    just Matt, Sharpone, e1956v and 2 others like this.
  14. Nostrebor
    Nostrebor
    First set of aftermarket wheels I purchased, at 16 years old, were also American Eagle faux Centerlines. :D They did a short stint on a 55 Chevy truck and then lived a full life on a 64 Chevy truck.
    I don't currently require a set.;)
  15. guthriesmith
    guthriesmith
    Love your truck! I had several of that body style 30 years ago or so. They look great lowered especially with the round wheelwell openings. Very cool!
  16. Phillips
    Phillips
    I'm old enough to remember when the '73 Chevy trucks came out! My personal crackpot theory is that the designer(s) loved the 55 Chevy and just drew up a square version for the 73 trucks!
    Sharpone, scotty t, swade41 and 5 others like this.
  17. Bentrodder
    Bentrodder
    from Cotati
    This is my old ‘86. Sorry no good pics on my phone but I had 3” drop spindles and cut 2 coils, my damn a-arms took a beating hitting things. Another thing to consider, which I didn’t when I was younger, was with spindles the control arm's are way below the scrub line if you get a flat.
  18. Here are some pics of my 86 I used to daily. Drove it from 2008-2020 daily. Had 215k when I sold it. It was lowered with 1.25 coils cut and a leaf taken out. Had 275/60r15 tires on all 4 corners. Screenshot_20260107_120115_Gallery.jpg Screenshot_20260107_120255_Photos.jpg Screenshot_20260107_120327_Photos.jpg
  19. I miss that old truck sometimes. I daily drove it 12 years, about 10-11k miles a year. It was a stock 305 (quadrajet) 700r4 and 2.73 rear. Averaged 14-15 mpg around town and flirted with 20mpg at 80mph.
    Looks like you got a good starting point and a great driver
  20. guthriesmith
    guthriesmith
    Some more cool pickups guys! I’m excited to get back on this project next week when I get back from Louisville. If nothing else, I need it to drive. :oops: Currently learning more about beekeeping. :D
  21. guthriesmith
    guthriesmith
    Yep, I need to work out the rear first as you mention. I like the ride height in the rear just not sure if the front has enough room left to look right overall. The front wheel wells are pretty dang shallow. Hoping I can empty the bed, see where I am at and then cut the front springs until I like it. At some point soon, I need to get the right tires and wheels on it since they will be about an inch different in height which will affect the rake obviously.
  22. Stooge
    Stooge
    Looks great! Ands whats one more white 80's C10 in this thread!
    The current iteration of my truck that ive owned 15'ish years now :rolleyes:
  23. Toms Dogs
    Toms Dogs
    from NJ
  24. swade41
    swade41
    from Buffalo,NY
    I started reading the first post and when I seen the 87 f-150 I totally wasn't interested in any build of one of those. As I'm scrolling down I'm wondering what is the lengthy story he's telling about this thing.. lol
    When I got to the photo I said hmmm, did he trade the Ford for a chevy, maybe I better go back and read this to see how that transpired !
    Nice score on that, it looks great, I never owned a square body truck but did have an 85 suburban with stepped A-arms and a rear flip kit. It did rub tire on the top of wheelwell, polished it pretty nice actually.
    At first I did the flip kit with an extended shackle, I couldn't get the jack out from under it so I put the stock shackles back in. Lol
    My daughter's boyfriend (Mat Seely) built this short fleet, he designs his own air setups and strategically raised the bed floor, front wheelwells and frame sections to all look stock if you didn't know better.
    So another photo of a white square.
    33Doll, just Matt, Tim and 8 others like this.
  25. foolthrottle
    foolthrottle
    Gone to Switzerland
      788.4 KB
      788.6 KB
  26. badshifter
    badshifter
    I fell for that affordable daily driver project in the middle of an engine swap too! IMG_2103.jpeg
  27. badshifter
    badshifter
  28. Phillips
    Phillips
    case in point
    Rolleiflex, just Matt, Tim and 8 others like this.
  29. guthriesmith
    guthriesmith
    Man, I was just thinking how Cragars would also look great on this pickup. That one with the narrow whitewalls is WAY cool.
    Yep, this is one of the ones I found a pic of when debating whether to buy the slots.
  30. e1956v
    e1956v
    Alliance Vendor
    IMG_4959.jpeg Jeff,
    Keeping an eye on this thread, getting ready to lower my 80 Silverado step side. Did a 5.3 LS 4L60E swap on it. IMG_4262.jpeg IMG_4264.jpeg IMG_4265.jpeg
