"New" Daily Driver Pickup "Project"
Discussion in 'Off Topic Hot Rods & Customs' started by guthriesmith, Dec 30, 2025.
  1. Sharpone
    Sharpone
  2. guthriesmith
    guthriesmith
  3. Sharpone
    Sharpone
    What ya mean our weather is perfect!
    For a polar bear.
    You got snow tires for the truck? Lol
    Dan
  4. guthriesmith
    guthriesmith
    Well, the tires that are on it now are a sort of all terrain. :p But, this stuff should be gone by the time it is out of the shop. Heading to the parts store now to get that stuff that I put on a list last night. Maybe I can finish up all the hoses, transmission cooling lines, etc. this evening.
  5. guthriesmith
    guthriesmith
    Got transmission mount and crossmember bolted up, transmission cooling lines on, fan shroud mounted, radiator hoses and heater hoses on, motor mount bolts tight, speedometer cable hooked up, and figured out that one of the torque converter bolts was standard and was supposed to be metric… Anyway, kinda nice that the previous owner had bought new transmission cooling lines. I likely wouldn’t have. Little by little…. Still need to put the exhaust manifolds back on to ****on up the exhaust as well as a few other little things under the hood. Maybe I can try to fire it up this week.
  6. guthriesmith
    guthriesmith
    So, just came out to the shop with all the broken bolts out of the manifolds thinking I could finish up the exhaust this evening. That is right until I realize that one of the flanges that should be hanging on the exhaust tube is missing?!?! :eek: Guessing they decided to cut it off instead of figuring out some other way to get the exhaust loose? So, I’m seeing only one way to get one back on and that involves cutting the exhaust in half and sliding another on since it won’t go over the flared end of the tube where it mates up to the manifold…. Or, looks like maybe I can cut a couple small welds at the muffler and slide it on from that end. The crazy things people do not thinking through the extra work they are creating. I guess I’ll find out if the part store stocks the flanges or if I am going to have to make one tomorrow.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. guthriesmith
    guthriesmith
    It is a three bolt flange and I will have one tomorrow. Had to order it at the parts store. I’ll put everything else together tonight and see if that joint comes apart easy at the muffler. If it doesn’t, that idea seems like a good one.
  10. guthriesmith
    guthriesmith
    That wasn’t terrible. Can’t finish the exhaust this evening, but making forward progress. Replaced all the studs in the manifolds, put new flange donuts in, cut the exhaust pipe apart at the muffler just grinding one half inch weld out and taking the clamp off to get that flange on, and mounting the manifolds back on the engine. Oh, and wondering how long this thing may have sat outside with the hood off after dumping a bunch of water out of the pipe I pulled off. :eek: Also swapped out all of the torque converter bolts since they seems to have lost one.
    just Matt, Deutscher, swade41 and 6 others like this.
  11. RMcCulley
    RMcCulley
    So close! Those wheels look great, that C notch is *****in!
  12. Ayers Garage
    Ayers Garage
    I can't tell from the pictures, but an R10 should have a bung for the oxygen sensor on the back of the driver's side manifold. You may find it easier to install the oxygen sensor on the bench and then install the manifold.
  13. guthriesmith
    guthriesmith
    You are correct and I did pull that oxygen sensor out after I pulled that manifold off to get the broken studs out. I definitely appreciate the reminder and now know that there was more than one reason I quit last night at 9:30 after getting the p***enger side manifold on. For some reason I fought that one more than should have ever been needed to get all the bolts started. I was trying to get the back two in last and was struggling. I finally pulled all the others out and put those two in first since I would rather fight ones that are easier to reach. Guessing the manifold is a slight bit deformed or something as they seem to get. Anyway, if it would have gone easy, I likely would have put the driver’s side on as well wondering why I didn’t first put that sensor back in while it was easy. :rolleyes: Thanks for saying something! :)
  14. rusty1
    rusty1
    ...the later manifolds like yours had a stiffener bar between the ports, the ones like yours tend to "move a bit.
  15. RodStRace
    RodStRace
  16. guthriesmith
    guthriesmith
    Interesting...not sure I knew that even though that might have been the case with the ones that were on a 92 pickup that I rebuilt the engine in about 25 years ago. I don't remember fighting them like I did these and also haven't ever had that issue on older ones like the rams horn style on most things I have worked on.
    Strangely enough, I either read about or was talking to someone about these spreaders just in the last few days for some other context. But, I was sure thinking about them last night wondering if I wasn't going to need to get some. In the end, I was at least able to get all 6 bolts in that p***enger side and everything tightened up good. And, since the driver's side was already on, I think I can get those back in as well with just lots of wiggling while starting bolts. :D
  17. RodStRace
    RodStRace
    In my experience at the used car lot that had to get modified vehicles back to smog legal, heavier trucks and RVs were the worst. More WOT hot usage. The p***enger side rear tended to be the more commonly warped. Don't know how useful this is, but that was what I saw.
    Hope you slathered the bolts and washers with anti-seize.
  18. guthriesmith
    guthriesmith
    Hmm…I didn’t use any anti-seize and never have on SBC’s. Am I missing something there? I know some other engines have had issue with bolts getting seized up in heads but have never seen that on a SBC.
  19. RodStRace
    RodStRace
    The reason the holes in ends of the manifolds are bigger than the bolts is because the manifolds get hot and expand. That's why they have the washers, too. So the manifold lengthens when hot and shrinks when it cools. If the holes were tight around the bolts, they would snap them off.
    Add in the way the heat cycles tend to cook it all to bare metal that rusts, and you can really help future you by helping things slide and unscrew.
    It's true they aren't as bad as some other designs, but an ounce of prevention...
  20. guthriesmith
    guthriesmith
    Quick update...or explanation for lack of update maybe? :oops: I didn't really accomplish anything at all last night after realizing that the exhaust flange that I ordered at the parts store was too small. Some dimensions on their descriptions might help. Anyway, I ordered two other possibilities that should be in today so hope to have at least what I need to ****on up the exhaust soon. I also took my daughter to pick up my grandson at his dad's and took my wife dinner at the nursing home where she works last night. So, those are my excuses for not getting anything done last night. Seems my goal of starting this thing this week isn't going to happen. And, my wife is also off the next two evenings so my progress will wait until Sunday evening for any more updates. If only I didn't have a job to go to during the day and I could lock myself in the shop, I could make progress a lot faster...I just couldn't afford to work on it. :p I have already gone past the month that I hoped it would take me to be driving this thing.
  21. RodStRace
    RodStRace
    First, you have made progress, so deadlines are not failure.
    Second, just about everyone knows that if you had just got it running, it would be tougher to do the drop on a running, driving truck.
    Third, happy wife (dinner, time together) beats a hobby, hands down.
  22. guthriesmith
    guthriesmith
    catdad49, Okie Pete, porkshop and 5 others like this.
  23. guthriesmith
    guthriesmith
    Turns out my wife had to work this evening so getting a few things done. But, it’s also 23 degrees outside and I am about done for the night since my shop is the same. I seemed to have now ordered a second incorrect exhaust flange so hoping the third may be correct. However, I’m also making a drawing of the one on the truck to make one at work Monday…. So, this evening, I have finished up the front and rear shocks including plumbing in the air lines for the rear shocks. No more bouncing the truck. :p Also continuing to look things over to make sure this thing is roadworthy soon. Oh, and used up the last of a package of 6 of these tags I bought several years ago. I also got the truck tagged and insured this week in preparation of what hopefully comes soon. :cool:
  24. guthriesmith
    guthriesmith
    One more thing I am debating and meant to look at last night. I see some sort of transparent blue silicone stuff around the intake gaskets both on the ends where it meets the block as well as down the sides where it mounts to the heads. Anyway, I am thinking I should likely just pull the intake and make sure that it is sealed up correctly before I ever fill this thing with antifreeze, etc. I am su****ious that they even used the end gaskets on the intake. I figure it is probably easier to pull it now to check everything than be frustrated later when it leaks and I need to be driving it...
  25. RodStRace
    RodStRace
    and now you don't need a step stool to work on it! :p
  26. guthriesmith
    guthriesmith
    That would be nice, and it is better. But, with it sitting on the lift, I still need something to stand on to reach stuff like the back bolts on exhaust manifolds, etc. I have been using a 5 gallon bucket that had hydraulic oil in it. That tipped on me the other night and I landed on the edge of the ramp for the lift and twisted my ankle pretty good. :oops: I would just push it off the lift and could reach things much easier, but then I wouldn't be able to lift it up and down easily to get to stuff underneath... First world problems...lol :D Not sure how I ever did this sort of stuff before I had a lift. :rolleyes:
  27. RodStRace
    RodStRace
    Those plastic buckets have an altered physical state. They stick well until they can cause damage or injury. Then they slip like teflon!
  28. guthriesmith
    guthriesmith
    Hopefully either I measured correctly on a part that was hard to measure on the pipe and with a tape measure or the one I ordered is correct. :rolleyes:
  29. guthriesmith
    guthriesmith
    Success! The flared end of the pipe was also pretty rusty and likely how the flange disappeared. So, I cut about a foot off and replaced that part of the pipe. This is why I have others weld for me when looks matter…. Now, just waiting until I get the other side all bolted back up to make sure I head the tailpipes out even before tightening everything down and welding the muffler back to the pipe. On the downhill slide now when it comes to the exhaust. I am waiting on a new set of washers for the manifolds since those also got lost somewhere apparently. I’ll just pull one bolt at a time to put those on. Tired of waiting. Oh, and bought intake gaskets since I would rather make sure that is right now instead of after it is driveable.
